BGP problem
i have a problem when using BGP to advertise routes. I have 4 branches and i need to advertise routes, but my log for bgp says:
OPEN error: bad router-id and the state is open sent from the local peer and the remote peer state is the same open sent
can anyone help me?
i try to run BGP through a VPN tunnel interface.
Sounds like maybe you have the same router ID on each side. They have to be different on each router
