I’m start using BGP, it works but and I have some questions. Please help.
1., I use BGP in my own network, I don’t have own AS number (yet). I use differenct AS number in my router. Is it good idea, or I use same?
2., How can I advertise default gateway(s)?
3., I public connected and static. Is it enough? Is it a lot?
4., I use router-id parameter, is it needed?
5., I use multihop, if the other router is not the directly neighbour. Is it good? What can i do, if I have a triangle with 3 router?
6., Can I priorize?
thank you.
gyoztes
