BGP RB1100
2 провайдера
BGP
AS у меня.
AS у моего клиента.
RB1100 достаточно будет?
2 provider
BGP
AS I have.
AS my client.
RB1100 is enough?
An RB1100 should be able to take two full BGP tables and advertise your own IP ranges upstream. The memory you have depends on the exact model. If buying a new unit for the job it is also worth considering an entry level CCR if the ports meet requirements.
No issues with an 1100, but as Celtic said a lower CCR will work well.
A CCR1009 will easily take two tables and have plenty of horsepower left over for forwarding. What are your throughout requirements?
