BGP route filtering
Hi, I am running BGP internally on my network - this works well most of the times, however there are two things I can’t work out how to do
with “advertise connected” routes enabled, I want to be able to filter out a specific route so it is not advertised at all. This is usually a subnet attached to an Ethernet interface that is masqueraded onto the larger network.
Example1
interface IP addresses
Wlan1 172.20.20.5/30
Wlan2 172.20.20.9/30
Ether1 192.168.0.1/24
I would like the router to collect routes and advertise routes on Wlan1 & Wlan2, but not advertise 192.168.0.0/24 that is bound to Ether1
Any assistance in accomplishing this would be greatly appreciated
*) set out-filter in bgp peers configuration
*) add routing filter
/routing filter add chain= prefix=192.168.0.0/24 action=discard
Excellent - thanks for that - much appreciated
Is it possible to add a list of prefixes to a filter
for example filter out
192.168.0.0/16
10.0.0.0/8
172.18.0.0/24
/routing filter add chain= prefix=10.0.0.0/8 action=discard
/routing filter add chain= prefix=172.18.0.0/24 action=discard
Hi all :slight_smile:
When I do the same but only for OSPF nothing is happened :frowning:
R1:
/routing filter add chain=ospf-out prefix=192.168.0.0/24 type=connect action=discard
Route 192.168.0.0/24 still appears on my R2…
Is there any additional config for OSPF for route filter?
remove type=connect
Thanks a lot, I’ll try that :slight_smile:
