Hello all,
Can someone help me identify why my Mikrotik won't utilize the BGP learned routes? I have a CCR1072 that runs iBGP with a Juniper QFX5100. The CCR1072 receives all the required routes from the Juniper, but it doesn't install them inside the routing table. I currently have static routes for those networks until the BGP issue is resolved.
[atetu@emp-cle.edge-fw01.ccr1072] > ip route print where received-from=iBGP-Core-QFX5100
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme,
DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 Db 10.0.99.40/30 64.85.172.5 200
1 Db 10.10.100.0/24 64.85.172.5 200
2 Db 10.50.104.0/24 172.20.103.2 200
3 Db 10.50.106.0/24 172.20.106.2 200
4 Db 10.50.109.0/24 172.20.109.2 200
5 Db 10.60.104.0/24 172.20.103.2 200
6 Db 10.103.0.0/22 172.20.103.2 200
7 Db 10.104.0.0/22 172.20.103.2 200
8 Db 10.106.0.0/22 172.20.106.2 200
9 Db 10.109.0.0/22 172.20.109.2 200
10 Db 10.224.0.0/22 172.20.103.2 200
11 Db 10.250.103.0/24 172.20.103.2 200
12 ADb 172.20.101.0/30 64.85.172.5 200
13 ADb 172.20.102.0/30 64.85.172.5 200
14 ADb 172.20.103.0/30 64.85.172.5 200
15 ADb 172.20.105.0/30 64.85.172.5 200
16 ADb 172.20.106.0/30 64.85.172.5 200
17 ADb 172.20.107.0/30 64.85.172.5 200
18 ADb 172.20.108.0/30 64.85.172.5 200
19 ADb 172.20.109.0/30 64.85.172.5 200
20 Db 172.25.103.0/24 172.20.103.2 200
