BGP Routing Filter, filtered prefix mysteriously show up in remote
I have two routers running 6.43.14, mipsbe. Both routers are connected via SSTP and do not have any other BGP peers except one session to each other. I am applying a filter on Router A, it get filtered correctly (not shown in Advertisements) however the prefix show up in Router B routing table and distance indicate 20 which is BGP. Anyone experience same issue?
Filter is applied under BGP instance and there is no out filter in the peer configuration. The same filter chain if applied on peer out filter works correctly, filtered prefix does not show up in remote.
