Hi.
It’s possible to have a BGP session with password authentication?
We found no way to do it. We are using 2.9.11
Thanks.
Hi.
Thanks.
It’s solved using the package routing-test instead of routing.
But theres no way to manage “routing-test” from the Winbox software.
Only “routing” package appears to be managed from the Winbox software.
There are plans to support that package in Winbox?
