Hi, I would like to know if anyone was able to successfully configure BGP signaled VPLS on ROSv7?
In the documentation there is a reference to Cisco Style BGP VPLS (https://help.mikrotik.com/docs/display/ROS/VPLS), but the sub-menu “/interface cisco-bgp-vpls” it is not present in RouterOS 7.3beta37.
IIRC BGP signaled VPLS is under
/interface/vpls/bgp-vpls/add
It should be BGP signaled if you using site-id instead of cisco-id.
for example if your AS is 65535 and RD is 111:
Hi oreggin, thanks for your attention.
On ROSv6 I use “/interface vpls cisco-bgp-vpls”, but I don’t find that option on ROSv7.
I take this opportunity and ask you if you have tested the operation of “/interface/vpls/bgp-vpls”.
I don’t think so. We are seeing strange behavior. A vpls interface is created against the route reflector, it disappears, it is recreated and it disappears again. This behavior is permanent.
However, I am not sure if we are configuring the service correctly. The configuration we use in ROSv6 is as follows:
I’m seeing this interface creation and deletion behaviour on v7.4.1 with BGP VPLS (Non-Cisco). Was there any special configuration that you had to apply to resolve or was it just fine in v7.3rc1?
Hi, we have set up same BGP VPLS config and still same problem on ROS 7.5, BGP vpls subinterfaces go up and down and are not BGP signaled, can you tell us how have you configured BGP on the router reflector and nodes? We use ibgp rr role for RR and ibgp for nodes, but something should be missing. When router reflector is using ROS6.48, all nodes using ROS6.8 have BGP VPLS signaled interfaces running, but those ones with ROS 7.5 remain stable and active but not BGP signaled. When we upgrade Router reflector to ROS 7.5 all the problems of unstability start.
Ok, well understood, that’s why I was so confused, apart from that I received this update from Mikrotik support:
“There is an issue with ibgp rr role. We have managed to reproduce the issue locally in our labs and look forward to fixing it on upcoming RouterOS versions, unfortunately, I cannot provide a release date now.”
So It’s not possible to have a fully working BGP signaled VPLS scenario on ROS 7.5. Also I noticed that if I use the ROS 7.5 in a node and 6.48 in router reflector, all devices with ROS 6.48 bring up the BGP signaled VPLSs, but in those running ROS 7.5, these BGP-VPLS are running, but not BGP signaled, and in MPLS LDP neighbors appear as “Invalid” due to the problems of BGP with ROS7.5, so I guess that this is not fully working and ROS 7.5 needs more work.
Thank you so much for your help and quick responses. Hope a new version comes up soon fixing this issue.
Has any progress been made toward fixing BGP route reflectors in v7? BGP VPLS won’t work for our setup until that’s fixed in v7, so our entire network is stuck on v6.
Could you please tell us your ticket ref for this? Some script reading joker in support told us to upgrade to v7 for a related issue we’re having (as if the lack of BFD wasn’t already a big no from us)
