I have a strange issue with BGP. Created peers, templates, filters and the configuration works.
As soon as I add an IP address to any interface with prefix /32, BGP connections are dropped and no connections is established. If I remove that IP address with /32 prefix, all peers come back. Can anyone find the culprit of misconfiguration?
This is configuration of bgp:
/routing bgp template
set default disabled=no routing-table=main
add as=254 disabled=no input.accept-nlri=scada-bgp-in-filter .filter=scada-in name=scada nexthop-choice=force-self output.filter-chain=scada-out .redistribute=connected,static,ospf,bgp router-id=192.168.21.254 routing-table=main
/routing bgp connection
add as=254 connect=no disabled=no input.accept-nlri=scada-bgp-in-filter .filter=scada-in listen=yes local.role=ibgp name=bps61 nexthop-choice=force-self output.filter-chain=scada-out .redistribute=connected,static,ospf,bgp remote.address=192.168.21.136/32 router-id=192.168.21.254 routing-table=main templates=scada
/routing filter rule
add chain=scada-in disabled=no rule="if (dst in 192.168.21.0/24) {reject}\r\
\nif (dst in 172.21.21.1/32) {reject}\r\
\nif (dst in 172.21.21.254/32) {reject}\r\
\nif (dst in 172.21.21.0/24 && dst-len>24) {accept}"
add chain=scada-out disabled=no rule="if (dst in 192.168.1.0/24) {accept}\r\
\nif (dst in 192.168.11.0/24) {accept}\r\
\nif (dst in 10.10.0.0/16) {accept}\r\
\nif (dst in 10.11.0.0/16) {accept}\r\
\nif (dst in 10.21.0.0/16) {accept}"
/ip firewall address-list
add address=127.0.0.1 list=scada-bgp-in-filter
If I add any IP address with prefix /32 to any interface on mikrotik, then all connections of bgp is dropped and does not reconnect, until I delete the IP if prefix /32.
No, its not redistributed, because bgp connections a immediately dropped and no reconnection is made.
The parameter equivalent to other vendors and older RouterOS “update-source” is “local.address”. In most cases, it can be left unconfigured, and let the router determine the address.
When a local address is not specified, BGP will try to guess the local address depending on the current setup:
if the peer is iBGP
if loopback available
pick the highest loopback address
if loopback is not available
pick any highest IP address on the router
if the peer is eBGP
if a remote peer’s IP is not from a directly connected network:
and multihop is not set, then throw an error
and multihop is enabled:
if a remote peer’s IP is from a directly connected network:
and multihop is not set:
pick the local routers IP address from that connected network
and multihop is set:
If left blank, incorrectly local address is selected when adding an IP with prefix /32 to any interface. So configuring Local address for peers configs resolves the problem.
