BGP/Strange behavior
I’ve noticed that a Router restarted all of its BGP Peerings.
Works as Backup-Router so I’vent noticed it too hard :smiley:
The log entry just before says:
“system info” “the proxy access rule added”
35 secs later:
“route bgp info” “TCP connection established”
and then the same for the other peerings.
Noone was logged in to that router and history shows:
“the proxy access rule added” the “By” field is empty!!!
This router has proxy disabled.
Version 2.9.43.
Lots of free memory (242MB) and no CPU load as it works
standby.
So what is happening here??? Does the webproxy package do strange
things without beeing enabled?? Package is enabled but disabled in settings.
Stefan
