I’m trying to redistribute routes to our internal devices - but as the routes are all marked as unreachable they are not being advertised.
41404 Db dst-address=2c0f:fd90::/32 gateway=2001:19f0:ffff::1 gateway-status=2001:19f0:ffff::1 unreachable distance=20 scope=40 target-scope=30 bgp-as-path="64515,20473,17819,2914,3356,37084,37185" bgp-origin=igp
bgp-communities=64515:44 received-from=peer6_vultr
41405 Db dst-address=2c0f:fda8::/32 gateway=2001:19f0:ffff::1 gateway-status=2001:19f0:ffff::1 unreachable distance=20 scope=40 target-scope=30 bgp-as-path="64515,20473,17819,4826,6939,37349" bgp-origin=igp
41406 Db dst-address=2c0f:fdb0::/48 gateway=2001:19f0:ffff::1 gateway-status=2001:19f0:ffff::1 unreachable distance=20 scope=40 target-scope=30 bgp-as-path="64515,20473,17819,2914,37100,33765" bgp-origin=igp
41407 Db dst-address=2c0f:fdc0::/32 gateway=2001:19f0:ffff::1 gateway-status=2001:19f0:ffff::1 unreachable distance=20 scope=40 target-scope=30 bgp-as-path="64515,20473,17819,2914,6453,36930" bgp-origin=igp
41408 Db dst-address=2c0f:fdc8::/32 gateway=2001:19f0:ffff::1 gateway-status=2001:19f0:ffff::1 unreachable distance=20 scope=40 target-scope=30 bgp-as-path="64515,20473,17819,4826,6939,37105,37049" bgp-origin=igp
Is there a way I can ignore the fact the router thinks they are unreachable?
Is there a way I can convince the router they are reachable? (it all works, and the next hop is reachable)
/ping 2001:19f0:ffff::1
SEQ HOST SIZE TTL TIME STATUS
0 2001:19f0:ffff::1 56 64 0ms echo reply
1 2001:19f0:ffff::1 56 64 0ms echo reply
2 2001:19f0:ffff::1 56 64 0ms echo reply
3 2001:19f0:ffff::1 56 64 0ms echo reply
4 2001:19f0:ffff::1 56 64 0ms echo reply
5 2001:19f0:ffff::1 56 64 0ms echo reply
6 2001:19f0:ffff::1 56 64 0ms echo reply
sent=7 received=7 packet-loss=0% min-rtt=0ms avg-rtt=0ms max-rtt=0ms
