does BGP implementation in Mikrotik supports:
WEIGHT attributes for peers (if I would like to prefer one peer before another)
IBGP (internal BGP support)
will the BGP support the same functionality like Zebra BGP?
We use the BGP in commercial / production environment with over 400mbps on GIGE lan feeds and it works well . We use 2.8 and that supports none of the below
—NO
—NO
will the BGP support the same functionality like Zebra BGP?[/quote]
—NO
BUT looking forward to 2.9 hopefully it supports all of the above. Not yet moved the Release Candidate to production .
Still for simple bgp you can use MT 2.8 it works well.
