BGP Support
Which mikrotik model support BGP routing for 2 DS3 line.
all mikrotik products support BGP. all routerboards have the same software
I mean to say any hardware limitation or any type of CPU utilisation Issue is there if i will use 2 DS3 line’s with BGP Routing.
Any routing table issue.
BGP is not about routing, it’s about routes distribution. if you don’t need BGP Full Views (just announce your network and receive default gateways), then there’s no limitations on BGP
