I turn to the forum for help in the BGP environment,
I would like to test my Mikrotik v7 BGP configuration to understand if I have set the filters properly.
To do this I wanted to simulate two BGP Peers through a .mrt dump of the Full Internet Routing Table but I have not found anything updated, such as guides, ready vm etc, to do this kind of test.
I had also thought of using other Mikrotik test routers but they do not support the import of the .mrt
Does anyone have any tools to recommend for this activity.
You could use some Linux machines with FRR (frrouting.org) as BGP peers which would feed you the routing table.
I referred to an old discussion and found the solution. http://forum.mikrotik.com/t/put-500-000-bgp-routes-in-your-mikrotik-for-testing-with-this-vm/94701/1
If I have difficulty I will try your advice. Thanks for the reply
