I have 2 routers and these routers have BGP configured and running.
What I want to do is to separate /24 and use these blocks into these two routers. Currently I am only able to use this block one of the router. Also even if I disable BGP session on X router, Y router cannot use these IPs even with the same config as router X and shown as IGP.
Router A configuration;
> routing bgp instance print
Flags: * - default, X - disabled
0 *X name="default" as=65530 router-id=0.0.0.0 redistribute-connected=
redistribute-static=no redistribute-rip=no redistribute-ospf=no
redistribute-other-bgp=no out-filter="" client-to-client-reflecti
ignore-as-path-len=no routing-table=""
1 name="router_1" as=2****6 router-id=10.***.4
redistribute-connected=yes redistribute-static=no redistribute-ri
redistribute-ospf=no redistribute-other-bgp=no out-filter=""
client-to-client-reflection=yes ignore-as-path-len=no routing-tab
> routing bgp peer print
Flags: X - disabled, E - established
# INSTANCE REMOTE-ADDRESS REMOTE-AS
0 E router_1 10.**3 34984
> routing bgp advertisements print
PEER PREFIX NEXTHOP AS-PATH ORIGIN LOCAL-PREF
rout... 123.456.789.0/24 10.***4 igp
> routing filter print
Flags: X - disabled
0 chain=FSIT_in invert-match=no action=accept set-bgp-prepend-path=""
1 chain=FSIT_out prefix=123.456.789.0/24 invert-match=no action=accept set-bgp-prepend-path=""
2 chain=FSIT_out invert-match=no action=discard set-bgp-prepend-path=""
Router B configuration;
1 name="router_2" as=2****6 router-id=10.***.6
0 E router_2 10.**5 34984
rout... 123.456.789.0/24 10.***6 igp
Flags: X - disabled
I tried to filter IPs, but then I couldnt see these IPs in Advertisement list.
So I have 2 issues;
1 - How could I divide /24 into these 2 BGP sessions? like 123.456.789.0/26, 123.456.789.64/26 router_1, 123.456.789.128/26, 123.456.789.192/26 for router_2
2 - Why I couldnt use my IPs entirely on router2 after disabling router1’s BGP session? Do I need to wait more than 10-15 mins in order to get route list to update or? Because I waited almost 10 minutes but I wasn’t able to use it on router_2. Router_1 and Router_2 has same configuration as well as same permissions
Thanks in advance.
