BGP v7 with 3 x upstream provider setup
Dear ALL,
We had 3 x upstream provider will full feed routing table, we can create the 3 x routing table to store the each upstream prefix, but how to put the best route in the main routing table?
Anyone can help?
TungHo
It sounds like you’re using different routing marks / vrf to learn each routing table
Is there a reason why it can’t all go into the same routing table? Then the best route will be determined automatically via the bgp best path process.
i had used v6.0, in v6.0, if i configured some rule to filter the prefix , i can’t see the filtered prefix, that why i’m looking to setup the different routing table to store the prefix.
Ok but that problem is no longer there in v7, you can see the filtered prefixes even when you use a single route table.
(most people don’t like that, but it looks like you are the one for which that change was made!)
