After upgrading a CCR2004 from RouterOS 7.19.6 to 7.20.6, BGP-VPLS (BGP L2VPN / l2vpn-cisco) stops working completely.
The BGP sessions come up, but the router no longer receives any l2vpn-cisco NLRI from the RR. As a result, VPLS instances do not establish and no L2 traffic passes.
On 7.19.6 everything works normally.
Symptoms on 7.20.6:
BGP sessions (iBGP) are Established.
PrefixCount = 0 in the session sometimes, even though IPv4 prefixes appear in RIB.
No L2VPN NLRI is installed, Dynamic VPLS interfaces not created.
Downgrading back to 7.19.6 immediately restores correct operation.
Configuration excerpt (works on 7.19.6):
/routing/bgp/export compact
2025-12-12 10:07:33 by RouterOS 7.19.6
software id = S7J1-YLF8
model = CCR2004-1G-12S+2XS
/routing bgp template
add afi=ip,l2vpn-cisco as=6879 cisco-vpls-nlri-len-fmt=auto-bytes comment=def disabled=no input.filter=RR-in multihop=yes name=def output.filter-chain=RR-out .network=\
"" .redistribute=connected,bgp-mpls-vpn routing-table=main
/routing bgp connection
add afi=ip,l2vpn-cisco cisco-vpls-nlri-len-fmt=auto-bytes connect=yes disabled=no input.filter=RR-in listen=yes local.address=172.20.200.12 .role=ibgp .ttl=20 \
multihop=yes name=bgp2 output.default-originate=never .filter-chain=RR-out .keep-sent-attributes=yes .network="" .redistribute=connected,bgp-mpls-vpn \
remote.address=172.20.222.0/32 .as=6879 .port=179 routing-table=main templates=def
add afi=ip,l2vpn-cisco cisco-vpls-nlri-len-fmt=auto-bytes connect=yes disabled=no input.filter=RR-in keepalive-time=1s listen=yes local.address=172.20.200.12 .role=\
ibgp .ttl=20 multihop=yes name=bgp1 output.default-originate=never .filter-chain=RR-out .keep-sent-attributes=yes .network="" .redistribute=connected,bgp-mpls-vpn \
remote.address=172.20.222.255/32 .as=6879 .port=179 routing-table=main templates=def
/routing bgp vpls
add bridge=v3112 bridge-cost=50 bridge-horizon=1 cisco-id=172.20.200.12&6879:3112 disabled=no export-route-targets=6879:3112 import-route-targets=6879:3112 name=v3112 \
pw-control-word=disabled pw-l2mtu=1552 pw-type=raw-ethernet rd=6879:3112 vrf=main
add bridge=v69 bridge-horizon=1 cisco-id=172.20.200.12&6879:69 disabled=no export-route-targets=6879:69 import-route-targets=6879:69 name=v69 pw-control-word=disabled \
pw-l2mtu=1552 pw-type=raw-ethernet rd=6879:69 vrf=main
Re-creating BGP sessions does not help.
Can someone confirm whether 7.20.6 breaks L2VPN-Cisco NLRI?
Is there an internal change or new option required for BGP-VPLS that is not documented?
