I have setup a lab environment to test BGP distributed VPLS over TE tunnels. I had started setting up the TE tunnels between 2 routers, but then I realized I should setup the BGP VPLS first. That is why there is a partial TE configuration.
Oswego 7 and Oswego 3 are configured as BGP reflectors. I configured the VPLS tunnel between Oswego 6 and Oswego 8. There isn’t connectivity between Ethernet ports on either side, and I’m not sure why.
[admin@Lab Oswego 8] /interface vpls> monitor 0
remote-label: 18
local-label: 19
remote-status:
– [Q quit|D dump|C-z pause]
[admin@Lab Oswego 6] /interface vpls> monitor 0
remote-label: 19
local-label: 18
remote-status:
From Oswego 6
01:22:33 route,bgp,debug,packet,raw RemoteAddress=10.2.254.5
01:22:33 route,bgp,debug,packet,raw Length=19
01:22:33 route,bgp,debug,packet,raw FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
01:22:33 route,bgp,debug,packet,raw 00 13 04
01:22:51 route,bgp,debug,packet KEEPALIVE Message
01:22:51 route,bgp,debug,packet RemoteAddress=10.2.254.2
01:22:51 route,bgp,debug,packet MessageLength=19
01:22:51 route,bgp,debug,packet,raw Received KEEPALIVE packet
01:22:51 route,bgp,debug,packet,raw RemoteAddress=10.2.254.2
01:22:51 route,bgp,debug,packet,raw Length=19
01:22:51 route,bgp,debug,packet,raw FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
01:22:51 route,bgp,debug,packet,raw 00 13 04
01:23:05 route,bgp,debug,timer KeepaliveTimer expired
01:23:05 route,bgp,debug,timer RemoteAddress=10.2.254.5
01:23:05 route,bgp,debug,packet,raw Sent KEEPALIVE message
01:23:05 route,bgp,debug,packet,raw RemoteAddress=10.2.254.5
01:23:05 route,bgp,debug,packet,raw Length=19
01:23:05 route,bgp,debug,packet,raw FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
01:23:05 route,bgp,debug,packet,raw 00 13 04
01:23:05 route,bgp,debug,packet Sent KEEPALIVE message
01:23:05 route,bgp,debug,packet RemoteAddress=10.2.254.5
01:23:05 route,bgp,debug,packet Length=19
From Oswego 8
01:26:27 route,bgp,debug,packet,raw 00 13 04
01:26:27 route,bgp,debug,packet Sent KEEPALIVE message
01:26:27 route,bgp,debug,packet RemoteAddress=10.2.254.2
01:26:27 route,bgp,debug,packet Length=19
01:26:37 route,bgp,debug,packet KEEPALIVE Message
01:26:37 route,bgp,debug,packet RemoteAddress=10.2.254.2
01:26:37 route,bgp,debug,packet MessageLength=19
01:26:37 route,bgp,debug,packet,raw Received KEEPALIVE packet
01:26:37 route,bgp,debug,packet,raw RemoteAddress=10.2.254.2
01:26:37 route,bgp,debug,packet,raw Length=19
01:26:37 route,bgp,debug,packet,raw FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
01:26:37 route,bgp,debug,packet,raw 00 13 04
01:26:41 route,bgp,debug,timer KeepaliveTimer expired
01:26:41 route,bgp,debug,timer RemoteAddress=10.2.254.5
01:26:41 route,bgp,debug,packet,raw Sent KEEPALIVE message
01:26:41 route,bgp,debug,packet,raw RemoteAddress=10.2.254.5
01:26:41 route,bgp,debug,packet,raw Length=19
01:26:41 route,bgp,debug,packet,raw FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
01:26:41 route,bgp,debug,packet,raw 00 13 04
01:26:41 route,bgp,debug,packet Sent KEEPALIVE message
01:26:41 route,bgp,debug,packet RemoteAddress=10.2.254.5
01:26:41 route,bgp,debug,packet Length=19
Oswego 7
jan/03/1970 19:25:47 by RouterOS 5.1
software id = 0L74-6KUS
add admin-mac=00:00:00:00:00:00 ageing-time=5m arp=enabled auto-mac=yes
disabled=no forward-delay=15s l2mtu=65535 max-message-age=20s mtu=1500
name=Loopback priority=0x8000 protocol-mode=none transmit-hold-count=6
set 0 arp=enabled auto-negotiation=yes disabled=no full-duplex=yes l2mtu=1526
mac-address=00:0C:42:2E:EB:7F mtu=1500 name=ether1 speed=100Mbps
set 1 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited
disabled=no full-duplex=yes l2mtu=1522 mac-address=00:0C:42:2E:EB:80
master-port=none mtu=1500 name=ether2 speed=100Mbps
set 2 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited
disabled=no full-duplex=yes l2mtu=1522 mac-address=00:0C:42:2E:EB:81
master-port=none mtu=1500 name=ether3 speed=100Mbps
set 3 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited
disabled=no full-duplex=yes l2mtu=1522 mac-address=00:0C:42:2E:EB:82
master-port=none mtu=1500 name=ether4 speed=100Mbps
set 4 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited
disabled=no full-duplex=yes l2mtu=1522 mac-address=00:0C:42:2E:EB:83
master-port=none mtu=1500 name=ether5 speed=100Mbps
/interface ethernet switch
set switch1 mirror-source=none mirror-target=none name=switch1
/ip ipsec proposal
set default auth-algorithms=sha1 disabled=no enc-algorithms=3des lifetime=30m
name=default pfs-group=modp1024
/mpls traffic-eng tunnel-path
add disabled=no name=te1 use-cspf=yes
/interface traffic-eng
add auto-bandwidth-avg-interval=5m auto-bandwidth-range=0bps
auto-bandwidth-reserve=0% auto-bandwidth-update-interval=1h bandwidth=
1Mbps bandwidth-limit=disabled disable-running-check=no disabled=no
from-address=10.2.254.2 mtu=1500 name=te1 primary-path=te1
primary-retry-interval=1m record-route=yes to-address=10.2.254.5
/port
set 0 baud-rate=auto data-bits=8 flow-control=none name=serial0 parity=none
stop-bits=1
/ppp profile
set default change-tcp-mss=yes name=default only-one=default use-compression=
default use-encryption=default use-ipv6=yes use-mpls=default
use-vj-compression=default
set default-encryption change-tcp-mss=yes name=default-encryption only-one=
default use-compression=default use-encryption=yes use-ipv6=yes use-mpls=
default use-vj-compression=default
/queue type
set default kind=pfifo name=default pfifo-limit=50
set ethernet-default kind=pfifo name=ethernet-default pfifo-limit=50
set wireless-default kind=sfq name=wireless-default sfq-allot=1514
sfq-perturb=5
set synchronous-default kind=red name=synchronous-default red-avg-packet=1000
red-burst=20 red-limit=60 red-max-threshold=50 red-min-threshold=10
set hotspot-default kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=
5
set default-small kind=pfifo name=default-small pfifo-limit=10
/routing bgp instance
set default as=65530 client-to-client-reflection=yes disabled=no
ignore-as-path-len=no name=default out-filter=“” redistribute-connected=
no redistribute-ospf=no redistribute-other-bgp=no redistribute-rip=no
redistribute-static=no router-id=0.0.0.0 routing-table=“”
add as=65531 client-to-client-reflection=yes disabled=no ignore-as-path-len=
no name=MPLS out-filter=“” redistribute-connected=no redistribute-ospf=no
redistribute-other-bgp=no redistribute-rip=no redistribute-static=no
router-id=10.2.254.2 routing-table=“”
/routing ospf-v3 instance
set default disabled=no distribute-default=never metric-bgp=auto
metric-connected=20 metric-default=1 metric-other-ospf=auto metric-rip=20
metric-static=20 name=default redistribute-bgp=no redistribute-connected=
no redistribute-other-ospf=no redistribute-rip=no redistribute-static=no
router-id=0.0.0.0
/routing ospf-v3 area
set backbone area-id=0.0.0.0 disabled=no instance=default name=backbone type=
default
/snmp
set contact=“” enabled=no engine-id=“” location=“” trap-target=0.0.0.0
trap-version=1
/snmp community
set public address=0.0.0.0/0 authentication-protocol=MD5 encryption-protocol=
DES name=public read-access=yes security=none write-access=no
/system logging action
set memory memory-lines=100 memory-stop-on-full=no name=memory target=memory
set disk disk-file-count=2 disk-file-name=log disk-lines-per-file=100
disk-stop-on-full=no name=disk target=disk
set echo name=echo remember=yes target=echo
set remote bsd-syslog=no name=remote remote=0.0.0.0 remote-port=514
src-address=0.0.0.0 syslog-facility=daemon syslog-severity=auto target=
remote
/system routerboard settings
set baud-rate=115200 boot-delay=2s boot-device=nand-if-fail-then-ethernet
boot-protocol=bootp cpu-frequency=300MHz enable-jumper-reset=yes
enter-setup-on=any-key force-backup-booter=no
/user group
add name=read policy=“local,telnet,ssh,reboot,read,test,winbox,password,web,sn
iff,sensitive,api,!ftp,!write,!policy”
add name=write policy=“local,telnet,ssh,reboot,read,write,test,winbox,password
,web,sniff,sensitive,api,!ftp,!policy”
add name=full policy=“local,telnet,ssh,ftp,reboot,read,write,policy,test,winbo
x,password,web,sniff,sensitive,api”
/interface bridge settings
set use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=
no
set ether2
set ether3
set ether4
set ether5
set switch1_cpu
/interface l2tp-server server
set authentication=pap,chap,mschap1,mschap2 default-profile=
default-encryption enabled=no max-mru=1460 max-mtu=1460 mrru=disabled
/interface ovpn-server server
set auth=sha1,md5 certificate=none cipher=blowfish128,aes128 default-profile=
default enabled=no keepalive-timeout=60 mac-address=FE:E2:88:97:5D:E0
max-mtu=1500 mode=ip netmask=24 port=1194 require-client-certificate=no
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption
enabled=no keepalive-timeout=30 max-mru=1460 max-mtu=1460 mrru=disabled
/interface sstp-server server
set authentication=pap,chap,mschap1,mschap2 certificate=none default-profile=
default enabled=no keepalive-timeout=60 max-mru=1500 max-mtu=1500 mrru=
disabled port=443 verify-client-certificate=no
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=10.2.254.2/32 disabled=no interface=Loopback network=10.2.254.2
add address=10.1.254.249/29 disabled=no interface=ether3 network=10.1.254.248
add address=10.1.254.241/29 disabled=no interface=ether1 network=10.1.254.240
add address=10.1.254.233/29 disabled=no interface=ether5 network=10.1.254.232
set allow-remote-requests=no cache-max-ttl=1w cache-size=2048KiB
max-udp-packet-size=512
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s
tcp-close-wait-timeout=10s tcp-established-timeout=1d
tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s
tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no
tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061
set pptp disabled=no
/ip neighbor discovery
set ether1 discover=yes
set ether2 discover=yes
set ether3 discover=yes
set ether4 discover=yes
set ether5 discover=yes
set Loopback discover=yes
set te1 discover=no
/ip proxy
set always-from-cache=no cache-administrator=webmaster cache-hit-dscp=4
cache-on-disk=no enabled=no max-cache-size=none max-client-connections=
600 max-fresh-time=3d max-server-connections=600 parent-proxy=0.0.0.0
parent-proxy-port=0 port=8080 serialize-connections=no src-address=
0.0.0.0
/ip service
set telnet disabled=no port=23
set ftp disabled=no port=21
set www disabled=no port=80
set ssh disabled=no port=22
set www-ssl certificate=none disabled=yes port=443
set api disabled=yes port=8728
set winbox disabled=no port=8291
/ip socks
set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
/ip ssh
set forwarding-enabled=no
/ip traffic-flow
set active-flow-timeout=30m cache-entries=4k enabled=no
inactive-flow-timeout=15s interfaces=all
/ip upnp
set allow-disable-external-interface=yes enabled=no show-dummy-rule=yes
/ipv6 nd
add advertise-dns=no advertise-mac-address=yes disabled=no hop-limit=
unspecified interface=all managed-address-configuration=no mtu=
unspecified other-configuration=no ra-delay=3s ra-interval=3m20s-10m
ra-lifetime=30m reachable-time=unspecified retransmit-interval=
unspecified
/ipv6 nd prefix default
set autonomous=yes preferred-lifetime=1w valid-lifetime=4w2d
/mpls
set dynamic-label-range=16-1048575 propagate-ttl=yes
/mpls interface
add disabled=no interface=all mpls-mtu=1508
/mpls ldp
set distribute-for-default-route=no enabled=no hop-limit=255 loop-detect=no
lsr-id=0.0.0.0 path-vector-limit=255 transport-address=0.0.0.0
use-explicit-null=no
/mpls traffic-eng interface
add bandwidth=100Mbps blockade-k-factor=3 disabled=no igp-flood-period=3m
interface=ether1 k-factor=3 refresh-time=30s resource-class=0 te-metric=1
use-udp=no
interface=ether5 k-factor=3 refresh-time=30s resource-class=0 te-metric=1
use-udp=no
/port firmware
set directory=firmware
/ppp aaa
set accounting=yes interim-update=0s use-radius=no
/queue interface
set ether1 queue=ethernet-default
set ether2 queue=ethernet-default
set ether3 queue=ethernet-default
set ether4 queue=ethernet-default
set ether5 queue=ethernet-default
/radius incoming
set accept=no port=3799
/routing bfd interface
set all disabled=no interface=all interval=0.2sec min-rx=0.2sec multiplier=5
/routing bgp peer
add address-families=l2vpn as-override=no default-originate=never disabled=no
hold-time=3m in-filter=“” instance=MPLS multihop=no name=“Oswego 3”
nexthop-choice=default out-filter=“” passive=no remote-address=10.2.254.5
remote-as=65531 remove-private-as=no route-reflect=yes ttl=default
update-source=10.2.254.2 use-bfd=no
hold-time=3m in-filter=“” instance=MPLS multihop=no name=“Oswego 8”
nexthop-choice=default out-filter=“” passive=no remote-address=10.2.254.4
hold-time=3m in-filter=“” instance=MPLS multihop=no name=“Oswego 6”
nexthop-choice=default out-filter=“” passive=no remote-address=10.2.254.3
/routing mme
set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m
gateway-selection=no-gateway origination-interval=5s preferred-gateway=
0.0.0.0 timeout=1m ttl=50
/routing ospf area
default
add area-id=0.0.0.3 disabled=no instance=default name=Lab type=default
/routing ospf instance
set default disabled=no distribute-default=never in-filter=ospf-in
metric-bgp=auto metric-connected=20 metric-default=1 metric-other-ospf=
auto metric-rip=20 metric-static=20 mpls-te-area=Lab mpls-te-router-id=
Loopback name=default out-filter=ospf-out redistribute-bgp=no
redistribute-connected=no redistribute-other-ospf=no redistribute-rip=no
redistribute-static=no router-id=10.2.254.2
/routing ospf network
add area=Lab disabled=no network=10.2.254.2/32
add area=Lab disabled=no network=10.1.254.248/29
add area=Lab disabled=no network=10.1.254.240/29
add area=Lab disabled=no network=10.1.254.232/29
/routing rip
set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1
metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no
redistribute-connected=no redistribute-ospf=no redistribute-static=no
routing-table=main timeout-timer=3m update-timer=30s
/routing ripng
/store
add disabled=no disk=system name=web-proxy1 type=web-proxy
/system clock
set time-zone-name=manual
/system clock manual
set dst-delta=+00:00 dst-end=“jan/01/1970 00:00:00” dst-start=
“jan/01/1970 00:00:00” time-zone=+00:00
/system console
add disabled=no port=serial0 term=vt102
/system health
set
/system identity
set name=“Lab Oswego 7”
/system logging
add action=memory disabled=no prefix=“” topics=info
add action=memory disabled=no prefix=“” topics=error
add action=memory disabled=no prefix=“” topics=warning
add action=echo disabled=no prefix=“” topics=critical
/system note
set note=“” show-at-login=yes
/system ntp client
set enabled=no mode=unicast primary-ntp=0.0.0.0 secondary-ntp=0.0.0.0
/system ntp server
set broadcast=no enabled=no manycast=yes multicast=no
/system resource irq
set 0 cpu=auto
set 1 cpu=auto
set 2 cpu=auto
set 3 cpu=auto
set 4 cpu=auto
/system upgrade mirror
set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=
0.0.0.0 user=“”
/system watchdog
set auto-send-supout=no automatic-supout=yes no-ping-delay=5m watch-address=
none watchdog-timer=yes
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=
100
/tool e-mail
set address=0.0.0.0 from=<> password=“” port=25 username=“”
/tool graphing
set page-refresh=300 store-every=5min
/tool mac-server
/tool mac-server ping
set enabled=yes
/tool sms
set allowed-number=“” channel=0 keep-max-sms=0 receive-enabled=no
/tool sniffer
set file-limit=10 file-name=“” filter-address1=0.0.0.0/0:0-65535
filter-address2=0.0.0.0/0:0-65535 filter-protocol=all-frames
filter-stream=yes interface=all memory-limit=10 memory-scroll=yes
only-headers=no streaming-enabled=no streaming-server=0.0.0.0
/user aaa
set accounting=yes default-group=read interim-update=0s use-radius=no
Oswego 8
jan/03/1970 21:28:47 by RouterOS 5.1
software id = STHP-AD54
disabled=no forward-delay=15s l2mtu=1522 max-message-age=20s mtu=1500
name=A priority=0x8000 protocol-mode=none transmit-hold-count=6
mac-address=00:0C:42:34:0C:F0 mtu=1500 name=ether1 speed=100Mbps
disabled=no full-duplex=yes l2mtu=1522 mac-address=00:0C:42:34:0C:F1
master-port=none mtu=1500 name=ether10 speed=100Mbps
disabled=no full-duplex=yes l2mtu=1522 mac-address=00:0C:42:34:0C:F2
master-port=none mtu=1500 name=ether11 speed=100Mbps
disabled=no full-duplex=yes l2mtu=1522 mac-address=00:0C:42:34:0C:F3
master-port=none mtu=1500 name=ether12 speed=100Mbps
disabled=no full-duplex=yes l2mtu=1522 mac-address=00:0C:42:34:0C:F4
master-port=none mtu=1500 name=ether13 speed=100Mbps
set 5 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited
disabled=no full-duplex=yes l2mtu=1522 mac-address=00:0C:42:34:0C:F5
master-port=none mtu=1500 name=ether14 speed=100Mbps
set 6 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited
disabled=no full-duplex=yes l2mtu=1522 mac-address=00:0C:42:34:0C:F6
master-port=none mtu=1500 name=ether15 speed=100Mbps
set 7 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited
disabled=no full-duplex=yes l2mtu=1522 mac-address=00:0C:42:34:0C:F7
master-port=none mtu=1500 name=ether16 speed=100Mbps
set 8 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited
disabled=no full-duplex=yes l2mtu=1522 mac-address=00:0C:42:34:0C:F8
master-port=none mtu=1500 name=ether17 speed=100Mbps
/ip ipsec proposal
/port
stop-bits=1
/ppp profile
/queue type
sfq-perturb=5
5
router-id=10.2.254.4 routing-table=“”
router-id=0.0.0.0
default
/snmp
trap-version=1
/snmp community
set remote bsd-syslog=no name=remote remote=:: remote-port=514 src-address=::
syslog-facility=daemon syslog-severity=auto target=remote
enter-setup-on=any-key force-backup-booter=no silent-boot=no
/user group
add bridge=A disabled=no edge=auto external-fdb=auto horizon=none interface=
ether16 path-cost=10 point-to-point=auto priority=0x80
no
set ether10
set ether11
set ether12
set ether13
set ether14
set ether15
set ether16
set ether17
set switch1_cpu
default enabled=no keepalive-timeout=60 mac-address=FE:B2:F7:38:96:F1
/interface vpls bgp-vpls
add bridge=A bridge-cost=0 bridge-horizon=1 disabled=no export-route-targets=
1:1 import-route-targets=1:1 name=A route-distinguisher=1:1 site-id=1
/ip accounting
add address=10.1.254.238/29 disabled=no interface=ether10 network=
10.1.254.232
add address=10.2.254.4/32 disabled=no interface=Loopback network=10.2.254.4
add address=10.1.254.230/29 disabled=no interface=ether17 network=
10.1.254.224
set ether10 discover=yes
set ether11 discover=yes
set ether12 discover=yes
set ether13 discover=yes
set ether14 discover=yes
set ether15 discover=yes
set ether16 discover=yes
set ether17 discover=yes
set A discover=yes
/ip proxy
0.0.0.0
/ip service
/ip socks
/ip ssh
/ip traffic-flow
/ip upnp
/ipv6 nd
unspecified
/mpls
/mpls interface
/mpls ldp
add bandwidth=100Mbps blockade-k-factor=3 disabled=no down-flood-thresholds=
15,30,45,60,75,80,85,90,95,97,98,99,100 igp-flood-period=3m interface=
ether17 k-factor=3 refresh-time=30s resource-class=0 te-metric=1
up-flood-thresholds=15,30,45,60,75,80,85,90,95,97,98,99,100 use-udp=no
ether10 k-factor=3 refresh-time=30s resource-class=0 te-metric=1
/port firmware
/ppp aaa
/queue interface
set ether10 queue=ethernet-default
set ether11 queue=ethernet-default
set ether12 queue=ethernet-default
set ether13 queue=ethernet-default
set ether14 queue=ethernet-default
set ether15 queue=ethernet-default
set ether16 queue=ethernet-default
set ether17 queue=ethernet-default
/radius incoming
/routing bgp peer
hold-time=3m in-filter=“” instance=MPLS multihop=no name=“Oswego 7”
nexthop-choice=default out-filter=“” passive=no remote-address=10.2.254.2
remote-as=65531 remove-private-as=no route-reflect=no ttl=default
update-source=10.2.254.4 use-bfd=no
/routing mme
/routing ospf area
default
redistribute-static=no router-id=10.2.254.4
add area=Lab disabled=no network=10.2.254.4/32
add area=Lab disabled=no network=10.1.254.224/29
/routing rip
/routing ripng
/store
/system clock
/system console
/system health
set fan-mode=auto use-fan=main
/system identity
set name=“Lab Oswego 8”
/system logging
add action=memory disabled=no prefix=“” topics=bgp
/system note
/system ntp client
/system ntp server
set 0 cpu=auto
set 1 cpu=auto
set 2 cpu=auto
set 3 cpu=auto
set 4 cpu=auto
0.0.0.0 user=“”
/system watchdog
100
/tool e-mail
/tool graphing
/tool mac-server
set enabled=yes
/tool sms
/tool sniffer
/user aaa
Oswego 6
jan/03/1970 08:16:22 by RouterOS 5.1
software id = 6YTK-ICZ1
disabled=no forward-delay=15s l2mtu=1524 max-message-age=20s mtu=1500
mac-address=00:0C:42:A4:05:14 mtu=1500 name=ether1 speed=100Mbps
disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:A4:05:15
disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:A4:05:16
disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:A4:05:17
disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:A4:05:18
/ip ipsec proposal
/ppp profile
/queue type
sfq-perturb=5
5
router-id=10.2.254.3 routing-table=“”
router-id=0.0.0.0
default
/snmp
trap-version=1
/snmp community
remote
set boot-device=nand-if-fail-then-ethernet boot-protocol=bootp cpu-frequency=
400MHz force-backup-booter=no silent-boot=no
/user group
ether3 path-cost=10 point-to-point=auto priority=0x80
no
set ether2 vlan-header=leave-as-is vlan-mode=fallback
set ether3 vlan-header=leave-as-is vlan-mode=fallback
set ether4 vlan-header=leave-as-is vlan-mode=fallback
set ether5 vlan-header=leave-as-is vlan-mode=fallback
set switch1_cpu vlan-header=leave-as-is vlan-mode=fallback
default enabled=no keepalive-timeout=60 mac-address=FE:2B:08:D8:F7:45
1:1 import-route-targets=1:1 name=A route-distinguisher=1:1 site-id=2
/ip accounting
add address=10.2.254.3/32 disabled=no interface=Loopback network=10.2.254.3
add address=10.1.254.246/29 disabled=no interface=ether1 network=10.1.254.240
add address=10.1.254.222/29 disabled=no interface=ether4 network=10.1.254.216
/ip dhcp-server config
set store-leases-disk=5m
set A discover=yes
/ip proxy
0.0.0.0
/ip service
/ip socks
/ip ssh
/ip traffic-flow
/ip upnp
/ipv6 nd
unspecified
/mpls
/mpls interface
/mpls ldp
use-udp=no
interface=ether4 k-factor=3 refresh-time=30s resource-class=0 te-metric=1
use-udp=no
/port firmware
/ppp aaa
/queue interface
/radius incoming
/routing bgp peer
update-source=10.2.254.3 use-bfd=no
/routing mme
/routing ospf area
default
redistribute-static=no router-id=10.2.254.3
add area=Lab disabled=no network=10.2.254.3/32
add area=Lab disabled=no network=10.1.254.216/29
/routing rip
/routing ripng
/store
/system clock
/system console
add disabled=no term=vt102
/system health
set
/system identity
set name=“Lab Oswego 6”
/system logging
/system note
/system ntp client
/system ntp server
set 0 cpu=auto
set 1 cpu=auto
0.0.0.0 user=“”
/system watchdog
100
/tool e-mail
/tool graphing
/tool mac-server
set enabled=yes
/tool sms
/tool sniffer
/user aaa
Oswego 3
jan/03/1970 07:33:39 by RouterOS 5.1
software id = UH52-SKYA
set 0 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited
disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:70:12:F2
master-port=none mtu=1500 name=ether1 speed=100Mbps
disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:70:12:F3
disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:70:12:F4
disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:70:12:F5
disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:70:12:F6
/ip hotspot profile
set default dns-name=“” hotspot-address=0.0.0.0 html-directory=hotspot
http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=cookie,http-chap
name=default rate-limit=“” smtp-server=0.0.0.0 split-user-domain=no
use-radius=no
/ip hotspot user profile
set default idle-timeout=none keepalive-timeout=2m name=default shared-users=
1 status-autorefresh=1m transparent-proxy=no
/ip ipsec proposal
add disabled=no name=dyn use-cspf=yes
from-address=10.2.254.5 mtu=1500 name=te1 primary-path=dyn
primary-retry-interval=1m record-route=yes to-address=10.2.254.2
/ppp profile
/queue type
sfq-perturb=5
5
router-id=10.2.254.5 routing-table=“”
router-id=0.0.0.0
default
/snmp
trap-version=1
/snmp community
680MHz force-backup-booter=no silent-boot=no
/user group
no
set ether1 vlan-header=leave-as-is vlan-mode=fallback
default enabled=no keepalive-timeout=60 mac-address=FE:61:5E:D0:9D:3B
/ip accounting
add address=10.2.254.5/32 disabled=no interface=Loopback network=10.2.254.5
add address=10.1.254.225/29 disabled=no interface=ether5 network=10.1.254.224
add address=10.1.254.217/29 disabled=no interface=ether1 network=10.1.254.216
/ip hotspot service-port
set te1 discover=no
/ip proxy
0.0.0.0
/ip service
/ip socks
/ip ssh
/ip traffic-flow
/ip upnp
/ipv6 nd
unspecified
/mpls
/mpls interface
/mpls ldp
use-udp=no
use-udp=no
/port firmware
/ppp aaa
/queue interface
/radius incoming
/routing bgp peer
update-source=10.2.254.5 use-bfd=no
/routing mme
/routing ospf area
default
redistribute-static=no router-id=10.2.254.5
add area=Lab disabled=no network=10.2.254.5/32
/routing rip
/routing ripng
/store
/system clock
/system console
/system health
set
/system identity
set name=“Lab Oswego 3”
/system logging
/system note
/system ntp client
/system ntp server
set 0 cpu=auto
set 1 cpu=auto
0.0.0.0 user=“”
/system watchdog
100
/tool e-mail
/tool graphing
/tool mac-server
set enabled=yes
/tool sms
/tool sniffer
/user aaa
