I have no idea what i am doing wrong. I have a CCR1036-12G-4S EM router. We are setting up BGP between two ISP’s. ISP1 - ISP2 We are getting full routes from both ISP’s. We are also advertising 4 routes.
The problem is we get a OPEN error: authentication failure on the second ISP.
A little back story we originally had ISP2 working prior to moving over ISP1. We were routing fine. IP’s were propagating all was well. Then we hooked up ISP1. On ISP1 we were getting the authentication error. We connected the Carrier and they said we were sending them to many routes. During the trouble shooting we disabled ISP2 and ISP1 connect with no problems. But now we are getting the Authentication error on ISP2. - Same problem we are sending them to many routes
See config.
/routing bgp instance
set default as=62819 client-to-client-reflection=no router-id=XX.XXX.XXX.XX
/routing bgp network
add network=205.X.X.X/21 synchronize=no
add network=64.X.X.X/24 synchronize=no
add network=64.1.X.X/23 synchronize=no
add network=63.X.X.X/24 synchronize=no
/routing bgp peer
add name=toISP1-L3 out-filter=isp1-out remote-address=66.X.X.X remote-as=2XXX
add name=toISP2-CL out-filter=isp2-out remote-address=67.X.X.X remote-as=4XXX
/routing filter
add action=accept chain=isp1-out prefix=205.X.X.X/21
add action=accept chain=isp1-out prefix=64.X.X.X/24
add action=accept chain=isp1-out prefix=64.1.X.X/23
add action=accept chain=isp1-out prefix=63.X.X.X/24 set-bgp-prepend=3
add action=accept chain=isp2-out prefix=63.X.X.X/24
add action=accept chain=isp2-out prefix=64.1.X.X/24 set-bgp-prepend=3
add action=accept chain=isp2-out prefix=64.X.X.X/23 set-bgp-prepend=3
add action=accept chain=isp2-out prefix=205.X.X.X/21 set-bgp-prepend=3
add action=discard chain=isp1-out locally-originated-bgp=no
add action=discard chain=isp2-out locally-originated-bgp=no
In Winbox we are seeing under the advertisements tab
"There are to many advertisements to show them all.nPlease specify more specific Prefix filter.n
But when you click on "Or click to see them all. There are only 4 advertised routes to ISP1 and none to ISP2 as it is not connected.
I have no idea how we are sending routes from one Peer to another peer. any help here would be FANTASTIC.
We just upgraded to ROS6.28 (Yes i know bleeding edge but it fixed our negotiation problems)
