Big bug in OSPF ver 3.0 ...
OSPF bug in ROS ver 3.0 :
when I add a static route 10.20.20.0/24 in a Mktk ver3.0 router and enable “Redistribute Static Routes” the router is able to advertise the route throughout all OSPF routers (mostly Mktk 2.9.x and Cisco).
The problem occurs when I add the same route (different gateway) on a different OSPF router (VPDN router for example) for the backup reason.
After that I just deleted static routes from both routers but Mktk ver3.0 still shows 10.20.20.0/24 active !
If I do traceroute on my computer it shows me that Mktk ver3.0 is the origin of the route.
For me it looks like a bug … by certain reason Mktk ver3.0 is not able to properly recalculate new topology or Link-State Advertisement doesn’t work properly on Mktk ver3.0 !!!
Before we have run all routers on Cisco and Mktk 2.9 ROS’s and that problem never happened.
Every suggestion how to solve this bug would be great.
Thank you,
D.
