With nstreme disabled i get very bad results in bandwidth test.
UDP one way ~ 27Mbps which is ok, but in UDP both, TCP one way and TCP both the results are very bad.
Also, during the test, the CCQ drops from 90 to 10-20%, the rates from 54Mbps drops down to 6Mbps and the ping is too bad.
With nstreme enabled the results are OK.
UDP send & receive ~ 37Mbps
UDP both ~ 19Mbps
TCP send & receive ~ 24-30Mbps
TCP both ~ 10-15Mbps
During the test, the CCQ is 100%, the rates are at 54Mbps all the time and the ping is good (20-100ms).
I’m using 433ah + wistron cm9, offset dishes 80x85cm, hand maded feeders, 5.3km distance, tx power at 0dBm, -65dB signal strength and i have clear line of sight.
The only problem that i have with enabled nstreme is when i make a change in the AP (for example increasing the tx power), the client connects in about 1 minute. During this time i see in the log some “deauth”. When i make a change in the client, the ap connects immediatly.
I’m using WPA2 PSK encryption, ap-bridge - station pseudobridge.
Try unselecting some of your lowest datarates.
Retransmits may cause datarate scaling. which will at times be worse for performance than the retransmits.
I have tried all the combinations of data rates (and default) and always the same problem. When i make a change from ap side, the client reconnects after 1min.
