Big in DHCP Pool view in Winbox?
Can anyone else have a look at this?
Winbox 3.17
ROS 6.42.6
I have 2 DHCP scope, one for Home, one for Guest.
Then I also have an L2TP IPsec tunnel that uses an IP Pool.
Why do I not see the IP pool used by VPN under IP->Pool under Winbox?
How do I change the pool size from WinBox?
Cli is correct:
export
add name=DHCP-Pool-vlan1-Home ranges=10.10.10.55-10.10.11.254
add name=VPN-pool ranges=10.2.0.2-10.2.0.20
add name=DHCP-Pool-vlan20-Guest ranges=10.10.20.64-10.10.20.254
It is under IP->Pool. Not IP->DHCP Server..
Blush… :blush:
