Big newbie over here
Hi guys, so I love torrenting..
And recently I realized I need to open port in order to uTorrent to work propertly!
So after spending good half and hour time on local chat (of private tracker) I got some information. My router is MikroTik, and (i knew this before :wink: ) my wireless card is Alled Telesyn AT-WCP201G
So with http://www.whatismyip.com I got my IP.. It’s blablabla. I typed it as url and got page. I noticed login box at right top corner but as docs just said ā€œuser:admin, pass:blankā€. IT didn’t work!
I can’t login!!
I called my ISP, and they just said ā€œWe have nothing to do with this, Good Bye!ā€
What should I do? Netinstall confuses me a LOT! Please help
mmmm :confused: I don’t be sure but i suppose you can’t login to WinBOX
BY default the MKT login is User: Admin And Password: Blanck but firt you need select the router on the Connect To with this you can login.
If you continue with this trouble :stuck_out_tongue: reset the router from your MKT directly press the bottom RESET 15Sec.
Best Regard
