BIG pppoe problems. HELP plz
I have a great problem.
I use MT with the version 2.9.10. Everybody dials in with pppoe. Everything runs except for a thing perfectly.
I have customers that have a Linksys WRT54G router. This dials in about pppoe.
Sometimes this equipment causes problems and tries to build up hundreds of pppoe connections and takes the MT to fall out.
I can see his Mac address, far nothing.
I can forbid to let build up several connections ??
Help please
In 2.8
[admin@router] interface pppoe-server server>set one-session-per-host=yes
Not sure on 2.9 release.
Matt
It is the problem that MT does not recognize it.
One Session is only if one logged in already not if one wants to log in first.
This has not solved my problem.
I need help urgents
nobody have an idea??
Maybe you need to allow PAP etc.
I have activate PAP CHAP MSCHAP1 and 2 already.
This is not the problem.
Have you an other idea??
two day’s ago, I have the same problem again.
I need a solution.
Help me, please.
Well, i also have a strange one…
01:21:25 pppoe,info PPPoE connection established from 00:40:F4:D9:AD:08
01:21:25 pppoe,ppp,info <pppoe-0>: waiting for call...
01:21:27 pppoe,ppp,info <pppoe-0>: terminating...
01:21:27 pppoe,ppp,info <pppoe-0>: disconnected
01:21:33 pppoe,info PPPoE connection established from 00:40:F4:D9:AD:08
01:21:33 pppoe,ppp,info <pppoe-0>: waiting for call...
01:21:35 pppoe,ppp,info <pppoe-0>: terminating...
01:21:35 pppoe,ppp,info <pppoe-0>: disconnected
01:21:41 pppoe,info PPPoE connection established from 00:40:F4:D9:AD:08
01:21:41 pppoe,ppp,info <pppoe-0>: waiting for call...
01:21:43 pppoe,ppp,info <pppoe-0>: terminating...
01:21:43 pppoe,ppp,info <pppoe-0>: disconnected
01:21:49 pppoe,info PPPoE connection established from 00:40:F4:D9:AD:08
01:21:49 pppoe,ppp,info <pppoe-0>: waiting for call...
01:21:51 pppoe,ppp,info <pppoe-0>: terminating...
01:21:51 pppoe,ppp,info <pppoe-0>: disconnected
But it never crashed my Mtik…
Crashing must be caused by something else…
Some of these, so called ‘broadband routers’ are VERY troublesome. I actually believe the WRT54G was one of the units that we had troubles with.
They simply do what they want, no questions asked. It’s not a fault with MT, it’s a fault with the hardware and some really weird incompatibility between certain PPPoE Servers. In some instances, we managed to get a few semi-stable by changing the MTU… It worked for some, for others, it didn’t.
Had it before as well, spend extensive time debugging this, and the end result was that I stoped supporting these ‘broadband routers’ on the network.
They simply cause to much trouble.
In my case, 00:40:F4:D9:AD:08 is the only MAC address that connects every few seconds. But, it connects and DISconnects! So, it does not locks up my Mtik, just filling up the log with trash. I can live with it :slight_smile:
But, in franco`s case, that client connects, does not disconnect, and connects again, making every time a new connection… this is really weird :frowning:
Is there any possibility to ban the client by MAC?
It should help franco, at least it will fix his problem for a while… until a new strange client shows up…
Wireless registration tables?
In my case, I have more than 30 APs in town and surrounding villages, and VLANs are configured on our Mtik with PPPoE for almost every AP. APs are very mixed by its manufacturer. Who the hell will manually open every AP and enter the MAC? :slight_smile:
I did not mean to ban the MAC on AP, rather on PPPoE server
If you make a effort to just look arround in Winbox a little, you will see that you can also firewall (input, output, forward chains), based on mac address.
Go punch the mac address in there, and drop protocol=pppoe ?
It’s really not that difficult…
Yap, you`re right, but it simply does not work :frowning:
I made a rule in forward chain, in advanced typed in the MAC, and in action selected drop. In the list of available protocols, there is no pppoe, so I left it blank (all protocols).
Even then, this weird client comes every 5-6 seconds…
If I read your setup right, you are running the PPPoE server ON your MikroTik.
Then you better should place this MAC filter in the input chain rather than the forward chain…
Best regards,
Christian Meis
YES, im running PPPoE server ON Mtik.
I changed the rule to be in input, but still without luck :frowning:
Could you post the actual rule you have in your system?
Best regards,
Christian Meis
As a guess, the /ip firewall won’t match on this since it’s not IP, even though you can match MACs in there.
I would put the interface in a bridge group (even if it is the only one in there), run the PPPoE service on the bridge group, and block your problem MAC in /int bridge firewall (if 2.8) or /int bridge filter (if 2.9).
–Eric
I agree with Eflanery. The /ip firewall won’t match on this since it’s not IP.
I will try to play arround with bridge group and post here the results.
Thanx for your posts and help!
