The company network have a fiber optic cable for accessing the internet with RJ-45 at the end. Also there is a LAN network with 40 workstations. I have to make access to every computer in LAN.
Our ISP provides us with static IP address: 205.70.70.1/29 for Indonesia Internet eXchange with gateway/dns 205.70.20.1 and 205.80.80.40/29 for International with gateway/dns : 205.80.80.40
I habe WRAP board with two interfaces. I called first as “Public”, and second as “Local”
I have add the two public address and gateway with same dns. But how could for setting “Local” to provide two ip out-interface will be one Ip address?
please support me…(What i have to do with Nat?)
If I correctly understand your description, than add
local address to local interface e.g. 192.168.0.1/24
NAT rules have to be like these:
/ip firewall nat add chain=srcnat out-interface=iface_name action=src-nat to-addresses=first_address
/ip firewall nat add chain=srcnat out-interface=iface_name action=src-nat to-addresses=second_address
i really don’t ge it…
My chief said, i have to combine 2 network isp will be one network ip address
let say i make this rule like this :
[admin@ECMP-Router] ip address> print
ADDRESS NETWORK BROADCAST INTERFACE
0 192.168.0.254/24 192.168.0.0 192.168.0.255 Local
1 10.1.0.2/28 10.1.0.0 10.1.0.15 Public1
2 10.1.1.2/28 10.1.1.0 10.1.1.15 Public2
Add the default routes - one for ISP1 and 2 for ISP2 so we can get the ratio 1:3:
[admin@ECMP-Router] ip route> add gateway=10.1.0.1,10.1.1.1,10.1.1.1
[admin@ECMP-Router] ip route> print
C - connect, S - static, r - rip, b - bgp, o - ospf
DST-ADDRESS G GATEWAY DISTANCE INTERFACE
0 ADC 10.1.0.0/28 Public1
1 ADC 10.1.1.0/28 Public2
2 ADC 192.168.0.0/24 Local
3 A S 0.0.0.0/0 r 10.1.0.1 Public1
r 10.1.1.1 Public2
r 10.1.1.1 Public2
In order to access the internet from your lan (10.0.0.0/24), try the following rule:
for redirect rules i put :
add chain=dstnat in-interface=Local src-address=192.168.0.0/24
protocol=tcp dst-port=80 connection-mark=http-connection action=redirect
to-ports=8080
and for the Ip firewall mangle >
I put like this :
