hi guys
1st of all i have router with 4 ethernet ports … OK
Port1 = LAN
Port2 = DVB-s router
Port3= ADSL router
ok lets start from begining
i using ADSL + satllite one-way (which is coming throw port2)
the satllite ISP need PPTP to connected to his server
i was working gr8 and i was very happy every thing work as expected UNTELL the problem came
for me i m using ADSL for browsing Only
i have the following
ip route
AS 212.93.193.87/32 ← my adsl isp proxy r 10.0.0.2
just want to force Mikrotik proxy to forward proxy request to the adsl it worked gr8
also i did
AS 82.198.6.19/32 (this is my satellite isp server) r 10.0.0.2
so i forced the pptp to connected to the isp server throw ADSL
pptp connection when it was connected there is somthing called client ip and server ip (it was 82.198.5.31<-- server ip )
EVERY thing is gr8 on this case i was very very happy
THE problem ::
my satellite isp change his pptp server ip to 82.198.6.19 which is the same ip that pptp dailing to it
so once the pptp connected the ip route
SHowing that its only static its no more active static
the pptp disconnect also after 30 sec and the pinging to 82.198.6.19 from lan pc giving request time out
anything will help me i thing he is super
