Yes we used th Dude 3.1 to uppgrade…
i will be posting the Export if i sucess to export it…
we have also updated the Bios on the RB 113c and the RB112
to lates version…
Finaly i get out the Export conf. it took 10 min to get it via SSH…
XXXXXXX = removed IP and email adresses.
jan/27/2009 10:40:16 by RouterOS 3.19
set 0 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=
“” disabled=no full-duplex=yes mac-address=00:0C:42:15:BD:A7 master-port=
none mtu=1500 name=ether1 speed=100Mbps
set default authentication-types=“” eap-methods=passthrough group-ciphers=“”
group-key-update=5m interim-update=0s mode=none name=default
radius-eap-accounting=no radius-mac-accounting=no
radius-mac-authentication=no radius-mac-caching=disabled
radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username
static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=
none static-key-0=“” static-key-1=“” static-key-2=“” static-key-3=“”
static-sta-private-algo=none static-sta-private-key=“”
static-transmit-key=key-0 supplicant-identity=RBNET378 tls-certificate=
none tls-mode=no-certificates unicast-ciphers=“” wpa-pre-shared-key=“”
wpa2-pre-shared-key=“”
/interface wireless
set 0 ack-timeout=dynamic adaptive-noise-immunity=none allow-sharedkey=no
antenna-gain=0 antenna-mode=ant-a area=“” arp=enabled band=2ghz-10mhz
basic-rates-a/g=6Mbps basic-rates-b=1Mbps burst-time=disabled comment=“”
compression=yes country=sweden default-ap-tx-limit=0
default-authentication=yes default-client-tx-limit=0 default-forwarding=
yes dfs-mode=none disable-running-check=no disabled=no
disconnect-timeout=3s frame-lifetime=0 frequency=2437 frequency-mode=
regulatory-domain hide-ssid=no hw-retries=15 mac-address=
00:0C:42:05:D2:F9 max-station-count=2007 mode=station mtu=1500 name=wlan1
noise-floor-threshold=default on-fail-retry-time=100ms
periodic-calibration=enabled periodic-calibration-interval=60
preamble-mode=both proprietary-extensions=post-2.9.25 radio-name=
RBNET378|2M rate-set=default scan-list=default security-profile=default
ssid=RBVFES station-bridge-clone-mac=00:00:00:00:00:00
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps tx-power-mode=default
update-stats-interval=disabled wds-cost-range=50-150 wds-default-bridge=
none wds-default-cost=100 wds-ignore-ssid=no wds-mode=disabled
wmm-support=disabled
/interface wireless manual-tx-power-table
set wlan1 comment=“” manual-tx-powers=“1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,
6Mbps:17,9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps
:17,HT20-1:0,HT20-2:0,HT20-3:0,HT20-4:0,HT20-5:0,HT20-6:0,HT20-7:0,HT20-8:
0,HT40-1:0,HT40-2:0,HT40-3:0,HT40-4:0,HT40-5:0,HT40-6:0,HT40-7:0,HT40-8:0”
/interface wireless nstreme
set wlan1 comment=“” disable-csma=no enable-nstreme=yes enable-polling=yes
framer-limit=3200 framer-policy=exact-size
/ip ipsec proposal
set default auth-algorithms=sha1 disabled=no enc-algorithms=3des lifetime=30m
name=default pfs-group=modp1024
add name=pool1 ranges=192.168.1.5-192.168.1.200
add address-pool=pool1 authoritative=yes bootp-support=static disabled=no
interface=ether1 lease-time=3d name=server1
/port
set 0 baud-rate=auto data-bits=8 flow-control=none name=serial0 parity=none
stop-bits=1
/queue type
set default kind=pfifo name=default pfifo-limit=50
set ethernet-default kind=pfifo name=ethernet-default pfifo-limit=50
set wireless-default kind=sfq name=wireless-default sfq-allot=1514
sfq-perturb=5
set synchronous-default kind=red name=synchronous-default red-avg-packet=1000
red-burst=20 red-limit=60 red-max-threshold=50 red-min-threshold=10
set hotspot-default kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=
5
set default-small kind=pfifo name=default-small pfifo-limit=10
/queue simple
add burst-limit=0/0 burst-threshold=0/0 burst-time=0s/0s comment=“”
direction=both disabled=no dst-address=0.0.0.0/0 interface=wlan1
limit-at=512000/512000 max-limit=512000/512000 name=voipv2-upstream
packet-marks=voip parent=none priority=1 queue=
ethernet-default/ethernet-default total-queue=default-small
direction=both disabled=no dst-address=0.0.0.0/0 interface=ether1
limit-at=512000/512000 max-limit=512000/512000 name=voipv2-downstream
limit-at=2000000/2000000 max-limit=2000000/2000000 name=httpv2-upstream
packet-marks=http parent=none priority=2 queue=
limit-at=2000000/2000000 max-limit=2000000/2000000 name=httpv2-downstream
limit-at=2000000/2000000 max-limit=2000000/2000000 name=otherv2-upstream
packet-marks=other parent=none priority=4 queue=
otherv2-downstream packet-marks=other parent=none priority=4 queue=
limit-at=2000000/2000000 max-limit=2000000/2000000 name=p2pv2-upstream
packet-marks=p2p parent=none priority=8 queue=
limit-at=2000000/2000000 max-limit=2000000/2000000 name=p2pv2-downstream
/snmp
set contact=www.rbcom.se enabled=yes engine-boots=4 engine-id=“” location=
kund time-window=0 trap-sink=0.0.0.0 trap-version=1
/snmp community
set client address=0.0.0.0/0 authentication-password=“”
authentication-protocol=MD5 encryption-password=“” encryption-protocol=
DES name=client read-access=yes security=none write-access=no
/system logging action
set memory memory-lines=100 memory-stop-on-full=no name=memory target=memory
set disk disk-lines=100 disk-stop-on-full=no name=disk target=disk
set echo name=echo remember=yes target=echo
set remote name=remote remote=xxxxxxx:514 target=remote
/system routerboard settings
set baud-rate=115200 boot-delay=2s boot-device=nand-if-fail-then-ethernet
boot-protocol=bootp cpu-frequency=175MHz cpu-mode=power-save
enable-jumper-reset=yes enter-setup-on=any-key
/user group
add name=read policy=“local,telnet,ssh,reboot,read,test,winbox,password,web,sn
iff,!ftp,!write,!policy”
add name=write policy=“local,telnet,ssh,reboot,read,write,test,winbox,password
,web,sniff,!ftp,!policy”
add name=full policy=“local,telnet,ssh,ftp,reboot,read,write,policy,test,winbo
x,password,web,sniff”
/interface bridge settings
set use-ip-firewall=no use-ip-firewall-for-vlan=no
/interface ethernet mirror
set mirror-port=none source-port=none
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=
00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300
frames-per-second=25 receive-all=no ssid-all=no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name=“” memory-limit=10
multiple-channels=no only-headers=no receive-errors=no streaming-enabled=
no streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=192.168.1.1/24 broadcast=192.168.1.255 comment=“” disabled=no
interface=ether1 network=192.168.1.0
/ip dhcp-client
add add-default-route=yes comment=“” default-route-distance=0 disabled=no
interface=wlan1 use-peer-dns=yes use-peer-ntp=yes
/ip dhcp-server config
set store-leases-disk=5m
add address=192.168.1.0/24 comment=“” dns-server=89.18.104.4,89.18.104.5
gateway=192.168.1.1 netmask=24
set allow-remote-requests=no cache-max-ttl=1w cache-size=2048KiB
max-udp-packet-size=512 primary-dns=89.18.104.4 secondary-dns=89.18.104.5
/ip dns static
add address=192.168.1.1 disabled=no name=setup.rbcom.se ttl=1d
/ip firewall address-list
add address=62.80.200.53 comment=“” disabled=no list=SIPSERVERS
add address=83.140.41.62 comment=“” disabled=no list=SIPSERVERS
add address=83.140.41.61 comment=“” disabled=no list=SIPSERVERS
add address=83.140.41.56 comment=“” disabled=no list=SIPSERVERS
add address=192.168.1.0/24 comment=“” disabled=no list=MGMT
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s
tcp-close-wait-timeout=10s tcp-established-timeout=1d
tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s
tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no
tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
add action=accept chain=input comment=
“Allow mgmt traffic from chosen networks” disabled=no dst-port=20
protocol=tcp src-address-list=MGMT
add action=accept chain=input comment=“” disabled=no dst-port=21 protocol=tcp
add action=accept chain=input comment=“” disabled=no dst-port=22 protocol=tcp
add action=accept chain=input comment=“” disabled=no dst-port=23 protocol=tcp
add action=accept chain=input comment=“” disabled=no dst-port=80 protocol=tcp
add action=accept chain=input comment=“” disabled=no dst-port=8291 protocol=
add action=drop chain=input comment=“Drop all unwanted mgmt traffic”
disabled=no dst-port=20 protocol=tcp
add action=drop chain=input comment=“” disabled=no dst-port=21 protocol=tcp
add action=drop chain=input comment=“” disabled=no dst-port=22 protocol=tcp
add action=drop chain=input comment=“” disabled=no dst-port=23 protocol=tcp
add action=drop chain=input comment=“” disabled=no dst-port=80 protocol=tcp
/ip firewall mangle
add action=mark-packet chain=forward comment=“” disabled=no dst-address-list=
SIPSERVERS new-packet-mark=voip passthrough=no src-address=0.0.0.0/0
add action=mark-packet chain=forward comment=“” disabled=no dst-address=
0.0.0.0/0 new-packet-mark=voip passthrough=no src-address-list=SIPSERVERS
add action=mark-packet chain=forward comment=“” disabled=no dst-port=80
new-packet-mark=http passthrough=no protocol=tcp
add action=mark-packet chain=forward comment=“” disabled=no new-packet-mark=
http passthrough=no protocol=tcp src-port=80
add action=mark-packet chain=forward comment=“” disabled=no dst-port=443
http passthrough=no protocol=tcp src-port=443
add action=mark-packet chain=forward comment=“” disabled=no dst-port=53
http passthrough=no protocol=tcp src-port=53
new-packet-mark=http passthrough=no protocol=udp
http passthrough=no protocol=udp src-port=53
p2p p2p=all-p2p passthrough=no
other passthrough=no
add action=masquerade chain=srcnat comment=“masquerade hotspot network”
disabled=no src-address=192.168.1.0/24
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061
set pptp disabled=no
/ip neighbor discovery
set ether1 discover=yes
set wlan1 discover=yes
/ip proxy
set always-from-cache=no cache-administrator=webmaster cache-hit-dscp=4
cache-on-disk=no enabled=no max-cache-size=none max-client-connections=
600 max-fresh-time=3d max-server-connections=600 parent-proxy=0.0.0.0
parent-proxy-port=0 port=8080 serialize-connections=no src-address=
0.0.0.0
“#error exporting //ip proxy access”
“#error exporting //ip proxy cache”
“#error exporting //ip proxy direct”
/ip service
set telnet address=0.0.0.0/0 disabled=no port=23
set ftp address=0.0.0.0/0 disabled=no port=21
set www address=0.0.0.0/0 disabled=no port=80
set ssh address=0.0.0.0/0 disabled=no port=22
set www-ssl address=0.0.0.0/0 certificate=none disabled=yes port=443
set api address=0.0.0.0/0 disabled=yes port=8728
set winbox address=0.0.0.0/0 disabled=no port=8291
/ip socks
set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
“#error exporting //ip socks access”
/ip traffic-flow
set active-flow-timeout=30m cache-entries=4k enabled=no
inactive-flow-timeout=15s interfaces=all
/ip upnp
set allow-disable-external-interface=yes enabled=no show-dummy-rule=yes
“#error exporting //ip upnp interfaces”
/queue interface
set ether1 queue=ethernet-default
set wlan1 queue=wireless-default
“#error exporting //radius”
/radius incoming
set accept=no port=3799
/store
add comment=“” disabled=no disk=system name=web-proxy1 type=web-proxy
/system clock manual
set dst-delta=+00:00 dst-end=“jan/01/1970 00:00:00” dst-start=
“jan/01/1970 00:00:00” time-zone=+00:00
/system console
add disabled=no port=serial0 term=vt102
/system health
set fan-mode=auto use-fan=main
/system identity
set name=RBNET378
/system logging
add action=memory disabled=yes prefix=“” topics=info
add action=memory disabled=yes prefix=“” topics=error
add action=memory disabled=yes prefix=“” topics=warning
add action=echo disabled=yes prefix=“” topics=critical
/system note
set note=“” show-at-login=yes
/system ntp client
set enabled=yes mode=unicast primary-ntp=89.18.104.4 secondary-ntp=
89.18.104.5
/system scheduler
add comment=“” disabled=no interval=0s name=report_schedule_startup on-event=
report start-time=startup
add comment=“” disabled=no interval=1h name=report_schedule on-event=report
start-date=jan/01/1970 start-time=00:00:00
/system script
add name=report policy=ftp,reboot,read,write,policy,test,winbox,password
source=“; :delay 120s;/ip address print; /interface wireless registration-
table print; /tool e-mail send to="XXXXXXXXXX" subject=([/interface
wireless get wlan1 radio-name] . " Report " . [/system clock get date])
from=XXXXXXXX server=89.18.104.10 body=("" . [/interface wi
reless get wlan1 radio-name] . "" . [/ip address get [/ip addr
ess find interface=wlan1] address] . "" . [/interface wireles
s get wlan1 ssid] . "" . [/interface wireless registration-t
able get[/interface wireless registration-table find interface=wlan1] sign
al-strength] . "" . [/system resource get version] . "<
/SOFTWARE>"); :log info ("Reported to main-server at " . [/sys cl get
time] . " " . [/sys cl get date])”
“#error exporting //system upgrade”
/system upgrade mirror
set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=
0.0.0.0 user=“”
/system watchdog
set auto-send-supout=no automatic-supout=no no-ping-delay=5m watch-address=
none watchdog-timer=yes
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=10
/tool e-mail
set from=<> server=0.0.0.0
/tool graphing
set store-every=5min
“#error exporting //tool graphing interface”
“#error exporting //tool graphing queue”
/tool mac-server
add disabled=no interface=all
/tool mac-server ping
set enabled=yes
/tool sniffer
set file-limit=10 file-name=“” filter-address1=0.0.0.0/0:0-65535
filter-address2=0.0.0.0/0:0-65535 filter-protocol=ip-only filter-stream=
yes interface=all memory-limit=10 only-headers=no streaming-enabled=no
/user aaa
set accounting=yes default-group=read interim-update=0s use-radius=no
