Hi
Is it possible to use the userman for hotel billing in an isp settings
What i wish to do is that when a user logs in it should not ask for password from any body until the time expires
Please Advice
Hi
Please Advice
Hi All
Please don’t bother about this post again i have done it and just require all to know what i did
Since the setting on each of the clients router is that its a dhcp server
by default the destination ip will change when communicating with my network
what happened is simple when some one login using that IP everybody there is logged in as the mikrotik sees them as 1
if you wish to change this and your mikrotik to ask for password from each of the user just change your radio setting from dhcp to bridge
Hope this works
