bind messengers to wan2
dear all
i want to bind msn and yahoo messenger and voip to wan2 only.
any help please
10x in advance
hmm… simply use the src-nat tool and masq. approriate ports to go out the specified interface…
src-nat; action=masq. out-interface=wan2 port type=tcp port-range=corresponding ports for messenger apps.
you would have to create a seperate src-nate rule for the voip segment since it uses UDP,
sip port range= 5040-5080 … voice payload 10000-40000… remember they are both udp.
Although my help is a bit bare, it should help
Use policy-routing to accomplish scenario with two ISP connections, policy-routing redirects specific packets over different gateways.
hi
shall i masqurade both gateways?
then where shall i make the policy routing in the Nat or mangle?
:frowning:
plz help
policy routing could be used too for specific ports!! like if I want FTP,MSN,SMTP routes through GW1 and the other services POP3,IRC routes through GW2???
hi Maroon kefak
what ru doing for the dsl?
10x 4 the help but i need more help , examples plz.
shoukran men lebnan
