Hi…and i’m sure 'cause of my lack of mt’s knowlogde i was not able to to use the FAQ and bind a public ip to a local one. I use a setup generated HOTSPOT and after i put all the info provided by the FAQ still got the mt ip’s. Probably the HOSPOT creates a series of firewall commands which will execute first and not allow the later nat - dst/src procedures to work. Any of you guys have the same problem? I’m using 2.9.6 version…and by the way…used to work on 2.8.x and work perfectly without using the HOSPOT. thx.
What exactly does not work with IP-binding ?
Yes, there are some dynamic rules with HotSpot, you have to authenticate in HotSpot, than it should work.
After i put all the FAQ instructions (dst-nat and src-nat) still got the router’s ip address instead of the planned real ip address. thx
