BIOS for RB's: where to download and where is a change log
hi,
i seem to have problems to locate the BIOS for discontinued products of MT/RB. for the RB150 i have to guess it would be the same file than for the RB133 (same cpu). MT, can you somehow have a website with BIOS versions for ALL RB’s including the older models ? i am also missing a change log, in this way i never know when upgrade or when not.
regards
Jan
BIOS is included with RouterOS. Just go to “system routerboard” and type “upgrade”
changelog is here:
http://www.routerboard.com/files/rb-2.14/CHANGELOG
ok, but in many cases i can’t use the latest ROS version and need to be able to get the BIOS only or if i don’t use ROS at all i still like to get the BIOS somehow. a download page would just be that simple.
thanks for the link to the changelog.
Jan
sorry, have to come back to this… the changelog says:
What’s new in 2.14:
*) fixed nand boot on RB150 (broken in v2.13);
hmmm… you are not telling me thats all ? why is there a new bios for all other CPU’s as well ??? or do you simply like to have the “numbers look nice” ?
Jan
we keep the changelogs symmetrical so some changes are ommitted due to that reason …
the BIOS doesn’t have so many changes or updates …
Hi Normis ;
to check better than be in trouble .
i have RB 333 with L4 3.0 OS , i download the 3.9 from the site and need to upgrade the RB .
do i have to do upgrade from system only , what about the license will it be erased ? i want to be sure not to loose the license .
with best regards .
new BIOS 2.15 is on routerboard.com
What’s new in 2.15:
*) fixed RB333 overheating problem;
*) added support for microSD card on RB433;
Hi ;
do i to use this new BIOS if i upgrade to 3.9 ?
with best regards
:slight_smile:
http://wiki.mikrotik.com/wiki/How_to_keep_my_router_up-to-date
Hi ;
Thanks for the link .
i checked the ver for the BIOS , it is the latest 2.12
now i am looking for to upgrade the OS for the RB333 to 3.9 while the current one is 3.0 and i read many recommendations to upgrade and not to stay with 3.0 .
do i have to use auto upgrade ? or what ? i should be ware not to loose the license of the router board .
with best regards .
download the latest version (2.15)
copy this file to FILES
run New Terminal
/system routerboard print
/system routerboard upgrade
/system reboot
thats all
Hi ;
will do BIOS upgrade today , but what about upgrading the OS to 3.9 without loosing the license ?
with best regards .
Hi ;
How to download the BIOS from routerboard.com ? there is no link for download .
with best regards .
http://www.routerboard.com/comparison.html
under every board there is link for download
Hi ;
Thanks , when i click on the specs the page expanded to show the specs for the RB with the BIOS file .
i download the file named :
mpc8323-2.15.fwf
and i will use it to upgrade the RB , still waiting your guidance for upgrading the OS to 3.9 .
with best regards .
scroll above your post, there are instructions already. read this forum thread again
Hi Normis ;
you mean regarding upgrade to 3.9 without loosing the license ?
with best regards .
http://wiki.mikrotik.com/wiki/Upgrading_RouterOS
Hi Normis ;
Thanks for the link , i downloaded before all_packages-ppc-3-1.9 from the site and now i am downloading the file mentioned in the wiki page .
will do the upgrade for the RB today and start checking it before send it to the top of the tower .
with best regards .
:smiley:
Hi Normis ;
i did the upgrade for both the BIOS and the OS for my RB333 , now the BIOS ver 2.15 and the OS 3.9 which i will use as AP Bridge to transmit using three mini pci wireless lans as follow :
  1. EMP 8602s ----> 5 watt Alcon amplifier ----> D-link omni antenna .
  2. R52 ----> 3 watt Hyper link amplifier ----> 4 Hyper link 24dbi Grids .
  3. R52 ----> D-link omni antenna for short distance wireless clients .
i have a X86 pc with OS 3.6 and L4 , i will keep using it with the RB333 to handle the firewall and other configuration .
do you recommend to upgrade it to 3.9 ? , do i have to download the file routeros-x86-3.9.npk and use it or i have to download the iso image ?
with best regards and thanks .
