Bittorent and RouterOS Firewall
Hi all,
I have Mikrotik RouterBoard 750G. I still learn how to use it, but i was already able to set unbreakable firewall with help of google naturally. :laughing: This is so great firewall, that i need to open specific port and address for every service which I need to use. So my question is , in case that my firewall drops all traffic which is not accepted by rule, what rule should I create to accept Utorrent? I have already set NAT that forward necessary port, but what I had learnt from web, Utorrent use every time another port and IP, so i don’t know how I could push Utorrent connection outside firewall.
Neither setting allow p2p-all is not working.
Could someone help me to find answer for my newbie problem? :slight_smile:
You could enable UPNP and let utorrent open the port itself, or you can specify a port in the utorrent preferences and then forward that using NAT. Make
sure the option “randomize port each start” is unticked in preferences - connection in utorrent.
Hello, thanks for answer,but i would like to do it without unpn. This forwarding by NAT is working(randomize port is disabled), but Utorrent still try connect to some IP addresses and random ports, and as i I mentioned before, my firewall rules will block everything what is not allowed. I can see that this ports are just server, because when i try to connect to France or London, every time it is another IP and port.
I will post here my firewall rules later.
My firewall settings:
    "Allow traffic between wired and wireless networks" disabled=no \
    in-interface=ether2-local-master out-interface=ether2-local-master
add action=accept chain=forward comment=IPTV1 disabled=no dst-address-list=\
    IP_tv-addr protocol=tcp src-address-list=local-addr src-port=\
    1000-5000,9081,9082
add action=accept chain=forward comment="P2P Emule TCP" disabled=yes dst-port=\
    11158 protocol=tcp
add action=accept chain=forward comment="P2P Emule UDP" disabled=yes dst-port=\
    12862 protocol=udp
add action=accept chain=forward disabled=yes dst-address=178.86.3.184 \
    dst-port=4184 protocol=tcp src-address=192.168.88.251 src-port=3484
add action=accept chain=input comment=IGMP disabled=no protocol=igmp
add action=accept chain=input disabled=no protocol=udp
add action=accept chain=forward disabled=no protocol=udp
add action=jump chain=forward comment="Sanity Check Forward" disabled=no \
    jump-target=sanity-check
add action=jump chain=sanity-check comment="Deny illegal NAT traversal" \
    disabled=no jump-target=drop packet-mark=nat-traversal
add action=add-src-to-address-list address-list=blocked-addr \
    address-list-timeout=1d chain=sanity-check comment="Block port scans" \
    disabled=no protocol=tcp psd=20,3s,3,1
    address-list-timeout=1d chain=sanity-check comment="Block TCP Null scan" \
    disabled=no protocol=tcp tcp-flags=fin,psh,urg,!syn,!rst,!ack
    address-list-timeout=1d chain=sanity-check comment="Block TCP Xmas scan" \
    disabled=no protocol=tcp tcp-flags=!fin,!syn,!rst,!psh,!ack,!urg
add action=jump chain=sanity-check disabled=no jump-target=drop protocol=tcp \
    src-address-list=blocked-addr
add action=accept chain=public-services comment="SSH (22/TCP)" \
    connection-mark=ssh disabled=no
add action=jump chain=sanity-check comment="Drop TCP RST" disabled=no \
    jump-target=drop protocol=tcp tcp-flags=rst
add action=jump chain=sanity-check comment="Drop TCP SYN+FIN" disabled=no \
    jump-target=drop protocol=tcp tcp-flags=fin,syn
add action=jump chain=sanity-check comment=\
    "Dropping invalid connections at once" connection-state=invalid disabled=\
    no jump-target=drop
add action=accept chain=sanity-check comment=\
    "Accepting already established connections" connection-state=established \
    disabled=no
    "Also accepting related connections" connection-state=related disabled=no
    "Drop all traffic that goes to multicast or broadcast addresses" disabled=\
    no dst-address-type=broadcast,multicast jump-target=drop
    "Drop illegal destination addresses" disabled=no dst-address-list=\
    illegal-addr dst-address-type=!local in-interface=ether2-local-master \
    jump-target=drop
add action=jump chain=sanity-check comment="Drop everything that goes from loca\
    l interface but not from local address" disabled=no in-interface=\
    ether2-local-master jump-target=drop src-address-list=!local-addr
add action=jump chain=sanity-check comment="Drop illegal source addresses" \
    disabled=no in-interface=ether1-gateway jump-target=drop src-address-list=\
    illegal-addr
    "Drop everything that goes from public interface but not to local address" \
    disabled=no dst-address-list=!local-addr in-interface=ether1-gateway \
    jump-target=drop
add action=accept chain=forward comment=BSGO disabled=yes dst-address-list=\
    BSGO-addr dst-port=27051,27050,9338,843 hotspot="" protocol=tcp \
add action=accept chain=forward comment=STO disabled=yes dst-address-list=\
    STO-addr dst-port=7000-7500 hotspot="" protocol=tcp src-address-list=\
    local-addr
add action=accept chain=forward comment=VPN disabled=yes dst-address-list=\
    VPN-addr dst-port=500,4500,10000,86 protocol=udp src-address-list=\
    local-addr
add action=accept chain=forward disabled=yes dst-address-list=VPN-addr \
    dst-port=10000,86 protocol=tcp src-address-list=local-addr
    "Drop all traffic that comes from multicast or broadcast addresses" \
    disabled=no jump-target=drop src-address-type=broadcast,multicast
add action=jump chain=forward disabled=no jump-target=restrict-tcp protocol=\
    tcp
add action=jump chain=forward disabled=no jump-target=restrict-udp protocol=\
    udp
add action=jump chain=forward disabled=no jump-target=restrict-ip
add action=reject chain=restrict-tcp connection-mark=auth disabled=no \
    reject-with=icmp-network-unreachable
add action=jump chain=restrict-tcp comment="anti-spam policy" connection-mark=\
    smtp disabled=no jump-target=smtp-first-drop
add action=add-src-to-address-list address-list=approved-smtp \
    address-list-timeout=0s chain=smtp-first-drop disabled=no \
    src-address-list=first-smtp
add action=return chain=smtp-first-drop disabled=no src-address-list=\
    approved-smtp
add action=add-src-to-address-list address-list=first-smtp \
add action=reject chain=smtp-first-drop disabled=no reject-with=\
add action=jump chain=restrict-tcp connection-mark=other-tcp disabled=no \
    jump-target=drop
add action=jump chain=restrict-udp connection-mark=other-udp disabled=no \
    jump-target=drop
add action=jump chain=restrict-ip connection-mark=other disabled=no \
    jump-target=drop
    "Allow local traffic (between router applications)" disabled=no \
    dst-address-type=local src-address-type=local
add action=jump chain=input comment="DHCP protocol would not pass sanity checki\
    ng, so enabling it explicitly before other checks" disabled=no dst-port=67 \
    in-interface=ether2-local-master jump-target=dhcp protocol=udp src-port=68
add action=jump chain=input comment="Sanity Check" disabled=no jump-target=\
    sanity-check
add action=accept chain=local-services comment="Winbox (8291/TCP)" \
    connection-mark=winbox disabled=no
add action=jump chain=input comment="Dropping packets not destined to the route\
    r itself, including all broadcast traffic" disabled=no dst-address-type=\
    !local jump-target=drop
    "Allow pings, but at a very limited rate (5 packets per sec)" \
    connection-mark=ping disabled=no limit=5,5
add action=jump chain=input comment=\
    "Allowing some services to be accessible from the local network" disabled=\
    no in-interface=ether2-local-master jump-target=local-services
    "Allowing some services to be accessible from the Internet" disabled=no \
    in-interface=ether1-gateway jump-target=public-services
add action=jump chain=input disabled=no jump-target=drop
add action=accept chain=dhcp disabled=no dst-address=255.255.255.255 \
    src-address=0.0.0.0
add action=accept chain=dhcp disabled=no dst-address-type=local src-address=\
    0.0.0.0
add action=accept chain=dhcp disabled=no dst-address-type=local \
add action=accept chain=local-services comment="SSH (22/TCP)" connection-mark=\
    ssh disabled=no
add action=accept chain=local-services comment=DNS connection-mark=dns \
    disabled=no
add action=accept chain=local-services comment="HTTP Proxy (3128/TCP)" \
    connection-mark=proxy disabled=no
add action=log chain=local-services comment="Log & Drop Other Local Services" \
    disabled=no log-prefix=""
add action=drop chain=local-services disabled=no
add action=accept chain=public-services comment="Winbox (8291/TCP)" \
add action=accept chain=public-services comment="PPTP (1723/TCP)" \
    connection-mark=pptp disabled=no
add action=accept chain=public-services comment="GRE for PPTP" \
    connection-mark=gre disabled=no
add action=log chain=public-services comment=\
    "Log & Drop Other ether1-gateway Services" disabled=no log-prefix=""
add action=drop chain=public-services disabled=no
add action=accept chain=forward comment=uTorrent connection-mark=bittorrent \
    disabled=yes packet-mark=bittorrent src-address-list=local-addr
add action=log chain=drop comment="Log Everything that we drop" disabled=yes \
    log-prefix=""
add action=drop chain=drop disabled=no
