I’m looking to Auto Discover everything in my network from 192.168.0.0 to 192.168.255.255
The problem I’ve run into is the Auto Discover finds many IPs outside of this range. IPs I DO NOT want this to look at.
What’s the easiest way to stop Dude from looking at anything outside of said range but still have it Auto Discover what I’m wanting?
normis
October 27, 2006, 7:56am
3
you can set hops value, if you set it to one, it will not search beyond the devices in this network. this is AFAIR, not completely sure
This doesn’t work because devices outside of the range I want to scan are directly connected to a bridge within the range I want to scan.
As soon as I set the hops to anything above 0 it sees these devices and scans their entire network.
I need to be able to block from 0.0.0.0 to 191.255.255.255 and from 193.0.0.0 to 255.255.255.255
uldis
November 2, 2006, 10:22am
6
Set ‘Recursive Hops’ to 0, and disable ‘Add PPP Links’ checkbox. Then you
should get only devices within your specified range. To exclude IPs from that
range you can make address list and specify it as blacklist when discovering.
