Hi all,
Am using mikrotik RouterOs as my bandwidth controler as well as firewall. I want to block all ips which are not in the queue list so that only ips in my simple queue list will be able to pass through.
Any tips and helps …
Thanx
Hi all,
Thanx
How does simple queues added? Dynamically by ppp?
Simple queue is added manually …
Thnx
Then also add the IPs to an address list and drop traffic from IPs not on the list. How exactly you’d do that depends on your existing firewall rule set.
