i have a mikrotik router installed in a hospital, the hospital uses a hospital management systme software from the cloud. i want to block all internet browsing except to that one site (Cloud Hospital Management System).
In the menu IP Routes Routes you see the WAN with 0.0.0.0/0 and if you can change that only traffic to that addres will be routed. So not usingdo not create default Route in the Wan setup put define your own.
Two firewall rules: first one allows connections to hospital’s management system … second one drops all other connections.
It’s not this simple really, there are several connections and protocols which support connections to hospital’s management system, so when defining filter rules one has to take them all into account.
AAA:BBB:CCC:DDD - replace with CHMS(Cloud Hospital Management System) ip address
for out-interface=WAN replace WAN with actual wan interface name
If you have other networks, you must define src. addresses also in this rule and do not delete the global rule and define src. addresses exception in it!
Come on, “blocking” something by not really blocking it, but instead just letting packets go out with wrong source address, it’s not what I’d call good solution. Sure, it won’t work, because packets will be either dropped by something on the way, or even if not, target won’t know where to send responses, so mission will be accomplished. But wouldn’t it be better to really block it on your router?
Simple example (assumes that there’s default firewall rule that allows established connections):
You can add other hostnames if required. But the main question is whether even that will be enough, because the site can have other dependencies (external scripts for example) and if it’s something dynamic (random hostnames for some CDN), there’s no easy way how to allow them.
Hey. You can create address list with a domain name. The IP addresses will appear after domain name resolves in your address list as a dynamic records. Use this address list name with a “logical not” function of firewall. Like:
ip firewall filter add action=drop chain=forward in-interface=your_lan_interface(or interfaces of interface list) dst-address-list=!your_site_address_or_address-list
! - means not.
Make sure this rule is above normal forwarding rule.
Also the address list will always keep the domain addresses up to date with help of your dns servers in your Tik dns settings.
Yes, you can resolved domain names, but the original poster is asking about allowing a specific path on that domain (a URL). This will not work. RouterOS can’t do that.
I seem to be following you everywhere this morning (so I am behind in my schapps consumption too).
Are you saying that the resolving domain in address list is not possible in MT RouterOS OR
that the Ops question is not solvable AT ALL using MT equipment??
It seems a pretty legitimate type of request in this day and age of everyone using cloud services???
Yes and no. You can forget about allowing only individual urls, because nowaways you have to assume that everything uses https. So far it’s possible to filter by hostname with tls-host, but soon it will go away too. You’re left with just IP addresses. You can use address list to resolve hostnames to addresses, and it can be enough in some cases. If you know that you only need access to www.example.com, it’s easy (look at my previous post). If the website uses few other static hostnames to download stuff from (scripts, images, …), add them to list and it will work. But if it’s unpredictably using seemingly random addresses like xc-1sd-aasdj.adas.ad.asd.somecdn.tld, it’s difficult to do anything with that.
This whole thing would be better done somewhere else and on different level. Not on router and not with IP addresses. Especially in a place like hospital, I’d rather not give anyone there direct access to internet, only to some proxy server that would see hostnames and would be able to filter by them. It would still not solve the problem with unpredictable CDN addresses, but at least it would be easier to allow whole somecdn.tld. And most importantly, it could log all requests, so admin would be able to see what are users trying to do. And deal with trouble makers.
Blah blah blah some external proxy vomitage…
So to connect through the internet to cloud based software/server, a credible institution requiring adequate security, should provide access to said software to a plethora of ‘dummies’ basic users via Servers specially dedicated to this service?
How does this service get to the internet, through a router?
So when this server traffic hits the MT router, what rules would apply?
I am useless for most things MT and even worse at technical solutions involving other equipment but lets give the OP some hope please!!
From what I see, OP’s description is sort of vague. OP also skipped my previous helpful post, so we don’t know how much would that solution not work. It’s even possible that it could be enough, external dependencies were not brought in by OP (it’s just that it’s pretty common thing to have).
