Block an IP address from the Internet
Hi All,
Just trying to get my head around how to block an IP entering through the WAN onto a mail server on the LAN side.
For example the offending IP address is 5.188.206.123, which I wish to stop.
Viewing the various posts on this forum, I have implemented as below.. on outerOS 6.48
/ip firewall address-list
add address=5.188.206.123 list=blacklist
add action=drop chain=input src-address-list=blacklist
I can see using Torch the packets coming in..
However, the mail server is still being hit.
Checking the counters on the Firewall/Filter Rules, the counter against the drop on blacklist is not incrementing and the mail server is still being hit.
Please advise
https://apps.db.ripe.net/db-web-ui/query?searchtext=5.188.206.123
I suggest you:
5.188.206.123 => abuse@fastvps.biz
/ip firewall raw
add action=drop chain=prerouting src-address-list=blacklist
Chain=input is for traffic which terminates in router itself (source doesn’t matter, can be either internet or LAN).
Chain=forward is for traffic which passes router in any direction (e.g. source on intetnet, destination on LAN or sourde on LAN and destination on internet; if there are multiple LAN subnets, this chain also affects traffic between different LAN subnets)
Chain=output is for traffic originating from router itself (and is seldomly used)
And suggestion by @rextended is a fine one. Raw firewall filter does its magic even before connection tracking machinery starts to analyze packets.
Thanks mkx and rextended,
will try the raw filter and report..it to abuse.
Quite my fault for buying an item from Far East… and my email being abused.
solution from rextended works perfectly..Thanks
Also reported the offending IP address.
/ip firewall raw – interesting
Rgds
Mano
:slight_smile:
