Hi Mikrotik FOrum
I have an issue that I would like your best bid on the little problem
I Have an DMZ zone that are only on 1 port - and the port is connected to A single NIC - that i have on my VMware server - the subnet is a /27
In this Setup here - is there any how possible to create a rule that will block the traffic from 192.168.0.0/29 - towards 192.168.0.8/29 ?
Or is it just easier to create an new DMZ - an split it directly into seperate DMZ - But I have not a spare NIC i my VMware server
Since the setup is created as only 1 NIC → Could I create the VLAN1 og VLAN2 - and create the same VLAN on the NIC in VMware - and split it that way instead
Only reason - I have 2 Webservers - and a mailserver setup including a spamfilter that I would like not to communicate to each other.
I think the main issue here is that everything is going through the one NIC in both Mikrotik And VMware
Tia
/p
