Block DHCP Example CRS Does not work
The example in the Wiki here:
http://wiki.mikrotik.com/wiki/Manual:CRS_examples#Protocol_Level_Isolation
Does not work on my CRS210-8G-2S+IN units.
Are there additional steps?
I followed the steps outlined in that section closely, just subbing in the SFPone interface as the ‘uplink’.
I printed the ACL and the entries are there.
It just doesn’t block DHCP.
I have a verified rogue DHCP server on port 4 of one of these, with a CCR upstream handing out authoritative DHCP.
When I do the DHCP Alert feature on the upstream CCR it still shows the offending MAC address from the CSR port 4.
When I disable the customer on ether4 then the rogue DHCP MAC does not show up.
Am I missing something?
Is this example flawed?
Is there another way to do this?
I have this figured out for the RB260GS units in my network (attached picture).
I would like to just do the same thing with the CRS units as well.
Any thoughts or help is appreciated.
Thanks!
It occurs to me that the sample for DHCP filtering here may only work if the upstream is directly connected to the DHCP server/router.
I have it connected to a switch upstream that isn’t port isolated, so it’s probably leaking upstream to the switch.
Is there a modification to this example or another example where it just drops DHCP server responses on the ingress to the CRS from the rogue DHCP server?
