I am looking for the Block Diagram of the following devices:
- “SXT SA5 ac” [RBSXTG-5HPacD-SA]
- “LHG XL HP5” [RBLHG-5HPnD-XL]
Why is MikroTik not publishing it?
Already asked support ?
Could be someone simply forgot to publish it.
Thanks for the tip, I did it now! ![]()
I’ll report back on what happens.
About how long does it usually take for them to respond?
Support has already solved it!
It is now available on the Support & Downloads > Block Diagram site!
Thank you!
https://i.mt.lv/cdn/product_files/RBSXTG-5HPacD-SA_230706.png
https://i.mt.lv/cdn/product_files/RBLHG-5HPnD-XL_230732.png
That didn’t take long, did it ? ![]()
Yes! Thanks! ![]()
