Looking to add a firewall rule on the output chain that blocks all DNS packets other than to OpenDNS IP addresses.
Am I correct in that I need to add 2 filter rules on the output chain to allow packets to the 2 OpenDNS IP addresses (1 per IP) and then a block rule that needs to be UNDERNEATH the 2 allow rules (so that it is applied after the others)?
For machines from LAN behind router:
/ip firewall filter add chain=forward dst-address=1.1.1.1 dst-port=53 protocol=udp action=accept
/ip firewall filter add chain=forward dst-address=2.2.2.2 dst-port=53 protocol=udp action=accept
/ip firewall filter add chain=forward dst-port=53 protocol=udp action=dropThere is no need to apply filter to output chain, because it’ll take effect for traffic from router itself.
