Just upgread 2.9.41 from 2.9.27.
I was using Transparent web proxy and used to block .exe, .zip downloading.
Now how to block the same in MT 2.9.41. also need transparent mode.
I din’t found any Transparent mode in /IP PROXY
what package you are using web-proxy or weproxy-test?
In /System Packages, WebProxy Test is Showing..How to Install Web Proxy Packages
It does not matter, which proxy package is used.
Use ‘ip proxy access’ list to filter .exe downloads,
Access list menu provides information, how you can block traffic per extension,
http://www.mikrotik.com/testdocs/ros/2.9/ip/webproxy.php
It is Just Showing /IP PROXY..No WEB PROXY..
Just Tel me the SYNTEX for DROOPING .ZIP or >EXE File in PATH
Thanks in Advance
please read the document that sergejs posted
Normis,
In webproxy i am getting only PATH option..I dont know what Path i have to mention to block .mp3 files.
I am not getting URL option..I used to block url=“:.mp[3g]$” action=deny
I dont Know What to do. Please help
