Block DropBox with firewall
Hello to everyone ,
Can someone knows how to block traffic from dropbox , torrents , windows updates , etc ?
With Mikrotik Router firewall ?
Thank you!
As it’s HTTPS you need to block via DNS or IP range, not recommended. If bandwidth consumption is a concern then use queues or data limits for your users.
Try the tls-host field in a mangle rule. It works for me blocking other sites like Netflix.
And you can use the same marking in simple queues to rate limit.
Cheers,
Sent from my cell phone. Sorry for the errors.
