hello, I need help blocking .exe, .zip, .rar and etc downloads on https sites!
This is my first post on the forum, I thank the patience
You should search and read first before you made your first post.
I did not find anything relevant, can you help me please
Not possible unless you own all the client devices and install MITM root certs.
That is what I thought too, but this site claims otherwise.. I haven’t tested their claims though.
https://www.timigate.com/2016/01/stop-downloads-and-punish-offenders.html
Layer7 filter only works if Layer7 is not encrypted. With https, the request text is already encrypted and, as @R1CH wrote, unless you install MITM certs that request text is unreadable for router. Hence the filter will not be effective.
Indeed. That is why I commented on the article. ![]()
But then again, the article is two years old and back then, not everybody used free SSL certificates from LetsEncrypt … therefore probability of filtering some traffice was slightly higher than nowadays.
Comments were from last week though ![]()
Those rules would work if it is mixed content. The calls are then made to a non TLS site.
