Block GMAIL
I need to block gmail, can u show me how to possible it.
Regards,
Nishadul
Force all clients to use your DNS server. Add static entries for gmail to go nowhere. (127.0.0.1)
add action=drop chain=forward comment=“drop gmail” content=mail.google.com
I have added this firewall rules but gmail not stop
Not possible to block gmail with MikroTik ?
Have you tired bkuhn’s suggestion? It should work just fine.
For me it’s working
Give an example of working rule!
Seems like it should work… I just tried it, moved it to the top of my firewall list and am getting hits on the rule, but I’m still able to login, view email list and view messages. Maybe it’s works by blocking the DNS lookup rather than the HTTPS transfer? If that’s the case, restarting computer or flushing DNS on the computer may help the rule take effect…
Running RouterOS 6.29.1
I have try the rule with 2 different browsers and it’s working.
With the rule disabled i login with google chrome to gmail. Then i enable the rule and i don’t have the ability to do anything.
With the rule also enabled i try to go to http://www.gmail.com and the internet explorel refused, and the error it’s in picture in my previous post.
Just tried it on another computer that hadn’t visited mail.google.com before the rule was in place and it gave error “Secure Connection Failed” in Firefox… so it looks like it should work.
Nice :smiley:
so whats the problem with the old computer? does it need to clean the cache of browser?
can someone post an example with static dns for gmail block
Should go something like this
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add address=127.0.0.1 name=mail.google.com
add action=drop chain=input dst-port=53 in-interface=ether1 protocol=udp
add action=drop chain=input dst-port=53 in-interface=ether1 protocol=tcp
add action=drop chain=forward dst-port=53 protocol=tcp src-address=192.168.88.0/24
add action=drop chain=forward dst-port=53 protocol=udp src-address=192.168.88.0/24
replace 8.8.8.8,8.8.4.4 with your DNS servers, or leave them and use googles DNS
replace ether1 with your WAN interface if it is something other than ether1
replace 192.168.88.0/24 with your LAN IP/Mask
And you’ll have to restart the computer or run the following from the command prompt to clear cached DNS
Vista and Window 7: Click “Start” and type the word “Command” in the Start search field. …
In the open prompt, type “ipconfig /flushdns” (without the quotes).
I guess I also made the assumption that you are using your router IP address as primary DNS server either statically or configured in your DHCP server.
Yes, this rule is working after move it to the top of my firewall list. Thanks
You are welcome !
also you can try this
IP:Firewall:Layer7 Protocols:Add New
Name gmail
Regexp ^.+(mail.google.com).*$
IP:Firewall:Add New
Chain forward
Layer7 Protocol gmail
Action reject
Reject With tcp reset
