I have setup the below configuration
internet → cable modem ->Mikrotik ether1 → hotspot ether2 ->netgear router running as an AP → wireless clients
The MT is allocating ipaddresses from the hotspot to the clients. The problem I am having is that the clients can see each other as they are on the same network. I understand that if you use the Mikrotik as a wireless hotspot you can switch off the default foward which stops this happening. Can this be done if ether2 is running as a hotspot?
Thanks Mark
