Block https domain with bridge proxy
I need to block https://www.website.com
I put mikrotik bridge after internet gateway and tried with web proxy:
> ip firewall nat print
 0   ;;; default configuration
     chain=srcnat action=masquerade to-addresses=0.0.0.0
     out-interface=wlan1-gateway
 1   chain=dstnat action=redirect to-ports=8080 protocol=tcp dst-port=80,8080,443
ip proxy print
                 enabled: yes
             src-address: 0.0.0.0
                    port: 8080
            parent-proxy: 0.0.0.0
       parent-proxy-port: 0
     cache-administrator: webmaster
          max-cache-size: unlimited
           cache-on-disk: no
  max-client-connections: 600
  max-server-connections: 600
          max-fresh-time: 3d
   serialize-connections: no
       always-from-cache: no
          cache-hit-dscp: 4
             cache-drive: system
> ip proxy access print  detail
 0   dst-address=88.44.63.170 dst-port="" action=deny hits=0
 1   dst-address=62.211.67.37 dst-port="" action=deny hits=0
 2   dst-address=82.53.187.74 dst-port="" action=deny hits=0
but I still can access to website.com
where am I going wrong?
thanks
no one?
You can’t transparently proxy https, unless you can force a trusted CA certificate into all clients and then sign all websites with this certificate.
Mikrotik cannot do such a thing.
so, there’s no way to do this?
Correct
Perhaps with L7 you could look at the CN on the HTTPS certificate?
How?
I don’t have the config for you to paste into your router, but L7 filter pretty much greps the first 2KB of each connection:
http://wiki.mikrotik.com/wiki/Manual:IP/Firewall/L7
The Client Hello, the certificate exchange and the Server Hello are not encrypted so L7 filter would be able to match these [they each contain the Common Name, ie domain name], however a quick test with Wireshark suggests to me that you’re going to be getting close to the 2KB limit.
/ip proxy access
add action=deny dst-host=*website.com
Works with non-transparent proxy.
I use WPAD to inform clients about network proxy. Never tried with transparent proxying.
If you need to block only certain addresses it’s much easier to use this script:
http://wiki.mikrotik.com/wiki/Use_host_names_in_firewall_rules
