Not possible this way, https is secure for a reason - so you can’t check content
You could block specific sites by assigning their DNS names a fake IP, but to allow only one or two, I can’t see how.
You could allow only the LINE and Facebook IP addresses through TCP Port 443 and block any other connection, but you would have to know all the IP that they use, and there are a lot.
It is impossible to accurately get real dst-host name from HTTPS connection. HTTPS encrypts everything, including headers of HTTP request and host name within it. In which packets can we see the domain name? The only reliable filtering for HTTPS is based on IP addresses.
Hotspot server tries to guess the DNS name from given dst-ip by getting appropriate entry from DNS cache on hotspot router. If multiple host names have the same IP and at least two of them are in DNS cache, then it could pick wrong DNS name for that IP. It explains why access to www.youtube.com gets allowed even though it is disabled in walled garden rules.
I am not aware of any solution to this problem without some bad consequences. For example,
if we disable HTTPS pass-through completely, then a lot of sites (including most of google sites) would not work within walled garden anymore;
if we would disable access to any IP with 2 DNS names, then google.com (and probably a lot of other sites) would not work as well;
if we would want to see real host name, then web proxy would have to terminate HTTPS request locally by its own certificate - web browser would see, that it is not correct certificate and would either show security warning or show nothing at all. Also, HTTPS certificate processing takes a lot of CPU power - hotspot server could be overloaded easily.
Maybe you can enable web proxy on the Mikrotik, and then block all port 80&443 traffic, and then configure the browser to use the Mikrotik as a proxy. Then in the proxy configuration, block all but your desired websites.
The only thing missing in the blog is the http server to host the wpad.dat file. You could probably put a quick-and-dirty OpenWRT virtual on the Mikrotik to host the file…
I haven’t tried it, but perhaps the wpad.dat file’s location in the DHCP 252 option could be an ftp:// url, in which case you could host the file on the Mikrotik itself with FTP.
when this script working (add action=add-dst-to-address-list address-list=facebook chain=forward
layer7-protocol=facebook src-address=192.168.1.0/24) It is not working if (add chain=forward dst-address-list=facebook src-address=192.168.1.254 working )
I’ve confirmed that you can filter https:// sites using the web proxy feature of the Mikrotik, but only if you configure the browser to use the proxy server.
I set my home router up as a web proxy, and configured a computer at my office to use the home router as a proxy.
(In Internet Explorer, go into Tools > Internet Options > Connections TAB > LAN Settings button, and then check the checkbox for “Use a proxy server for your LAN” and in the address field, just type the IP of your Mikrotik, port: 8080)
You should probably also check the bypass proxy server for local addresses setting - but I’ll leave that up to you.
Once the browser explicitly uses the Mikrotik as a proxy, the Mikrotik can inspect the https:// host headers before establishing connections. You can then create a list of permitted hosts (dst host=*.facebook.com action=allow, and a second rule for dst host=fbcdn.net) and finally a deny rule. You could set up a redirect-to address with an “access denied” page on your deny rule - I think this URL must be non-ssl, but I didn’t play with it very long.
You’ll also want to find the URL that Facebook’s certificate verification / revocation lists use, so that you can permit these hosts also - because in my testing, I was getting a warning that IE couldn’t verify whether the certificate had been revoked. This would get annoying to your user.
