block ip address out from router
hello
i want ask a question, i have 10 PC,the Ip from 192.168.1.2 - 192.168.1.9, ip router 192.168.1.1 netmask 255.255.255.0
the question: how to block ip 192.168.1.10 - 192.168.1.254 it cannot conenct to internet and all protocol, i use mikrotik 2.9.2, so everyone cannot change the ip
i use simple queue for 192.168.1.2 - 192.168.1.9, this ip have bandwidth limiting
thank you very much, i am sorry for the english
firewall,arp table.for example: set arp to reply only on interface with address 192.168.1.1.add static entries from 192.168.1.2-192.168.1.9 to arp table.all others addresses will not work.sorry for my english :confused:
You can simple masquerade only packets from those 10 IPs :slight_smile:
But I suggest Alex solution use ARP static entries and interface mode to read-only
thank you very much for the answer, the answer correct, and i use your suggestion, thank you
now i have one question again
my network 192.168.9.0/24, i subnet /29
my router 192.168.9.1 netmask 255.255.255.248
client 1 get ip: 192.168.9.8/29 (192.168.9.9 - 192.168.9.15)
client 2 get ip: 192.168.9.16/29 (192.168.9.17-192.168.9.23)
client 1 have bandwidth 32kbps
client 2 have bandwidth 64kbps
my question, i want each client not use all ip (exp: client 1 can use 192.168.9.9 but 192.168.9.10-192.168.9.15 cannot use)
client 2 same like that
i use that because i am afraid client 2 can use ip from client 1, so i use that rule
can mikrotik 2.9.2 use that??? if can my i get the rule or links for my problem…so i can learn that
thank you very much for the suggestion and rule, i am sorry for my english
If you made correct IP ARP table it is impossible for clints to jump from 1 Ip to another - so there are no problems
Why you use subnetting, use one subnet /28 and create 1 simple queue for each client!
just an idea: would it not be better to use DHCP with static MAC-entries, for doing the management completely on the router.
thanks for the suggestion
could you give me soe firewall rule??? i am very thank you if i can get one sample, or do you have links for my problem?
thanks my friend
