Block IP after X login failures
Is there a way to automatically block IP-adresses after X times login failures and put them on the block list for XX hours?
So if host 66.344.222.35 is trying to login in my routerboard 5 times and do not succed, routerboard automatically put this IP to drop packets from it on the firewall.
is that possible?
Regards Peter
No, not natively supported.
You could, however, parse the log for failed login attempts, disabling accounts (or block IP) once a threshold is reached.
This should get you started: Log Parser - Event Trigger Script
To block ssh and ftp bruteforcers, use this one
http://wiki.mikrotik.com/wiki/Bruteforce_login_prevention
I can see the ip in the blacklist, however, the ip in the blacklist still attempting to access according to the log …
You need to put in a filter rule (preferably in the RAW table) to block the blacklisted IP’s
end up, i add this in:
add chain=input src-address-list=ssh_blacklist action=drop comment=“drop ssh brute forcers IP” disabled=no
That’s find, but make sure that the rule is placed above any accept rule for established connections.
