Hi all, it is possible to add multiple keyword for blocking with just one rule in web proxy access?, for example i need to block keyword:
test, second, third, so i’ve been trying to use like this in path of web proxy access:test, second, third, but it’s not working at all.
And why if i put same keyword in dst-host and path it will not work, for example i put test on dst-host: and path: in web proxy access
but it will not work.
Need advice and enlightment please and sorry for disturbing your time.
if you use both fields, logical ‘AND’ operation is used. so both server name and path on the server should contain ‘test’ to be matched by that rule (for example, 'http://test123.foobar.com/my/test/index.php)
Hi, thank’s a lot for your replies, dssmiktik i’ve been trying the rule that you mentioned above but still it can connect based on the keyword,
is there any kind of condition to do that, i used Mikrotik router OS v 3.11.
